welding, which one mig , tig, stick ? |
sk8kat1 |
Jan 19 2006, 11:00 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
I am tring to find out which is the best choice for teener reapair but also being used for building a rotiss for doing the repair work ..
any thoughts ... what are the pros and cons of each type? |
914GT |
Jan 19 2006, 11:07 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
This article by John Kelly is a good place to start.
flyloki |
Jan 19 2006, 11:10 AM
Member Group: Members Posts: 138 Joined: 20-October 03 From: 8:00 in Boise, Idaho Member No.: 1,264 |
If you have an extra 2 grand and time to learn a TIG is the best.
If just rotisserie and general stuff I'd get a millermatic 135. Three or four of my buddies have nice Migs that I can use so I'm getting this gas rig here http://www.cut-like-plasma.com/ If it works half as good in the videos I'm a be stoked. |
Rand |
Jan 19 2006, 11:50 AM
Yup. Mig is great, and easy. The way to go for what you're doing.
TIG is ultimate. It costs more and is more difficult to learn, but you can do some beautiful welds on different metals (aluminum, chromoly, etc.) |
sk8kat1 |
Jan 19 2006, 12:04 PM
that little torch thing is cool (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) -- I wonder the cost and availablity of the gases ?
seanery |
Jan 19 2006, 12:09 PM
I would second the Millermatic 135.
I love TIG, but MIG is much more affordable. |
McMark |
Jan 19 2006, 12:14 PM
I recommend MIG.
TIG is not only a lot more expensive but working the foot pedal while laying upside down is not easy. I guess if you have a rotisserie it's no problem. MIG is much easier to learn and much easier to use on a day to day basis. |
Porcharu |
Jan 19 2006, 01:05 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I would highly recommend a good MIG setup I love my Millermatic 185 and I use it all the time and would not be without it. I have one of those cut like plasma setups - it's OK but if I was going to do it again (and I am) I would just get a good "aircraft sized" oxy acet welding outfit. Don't get something like a Journeyman high end welding outfit, they are made for welding buildings and ships together and don't work well at all for thin stuff like our cars. Take a look here http://www.tinmantech.com/html/meco_midget_torch.php |
Crazyhippy |
Jan 19 2006, 01:14 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
I too recomend the MIg... but learn how to Tig, or Oxy Acet weld. It will make you understand what is going on 10x better.
BJH (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) |
Bleyseng |
Jan 19 2006, 01:15 PM
For teener welding a MIG with gas is by far the best to use and fairly cheap. Anyone with a little practice can weld lite gauge sheetmetal.
tat2dphreak |
Jan 19 2006, 01:16 PM
MIG is much easier and cheaper, if you graduate to TIG later... that's cool too!
stick is only good for heavy stuff... and a strong ass MIG can do that and make pretty welds every time |
sk8kat1 |
Jan 19 2006, 01:55 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) so how do you know if you should use co2 or agron or the mixed gas
seanery |
Jan 19 2006, 02:11 PM
the easy way is to ask the folks you get your gas from. Tell 'em what your doing and they'll suggest the right gas.
Mueller |
Jan 19 2006, 03:46 PM
believe it or not, they sell books on the subject at Home Depot or Amazon.com or other places designed for newbies....it wouldn't hurt to spend $12 and learn something (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ......I have many text books on welding from school....I use the cheap $12 pamplet/book I bought from Home Depot more often mostly for a quick referance....... MIG is pretty affordable (low range start in the few hundred bucks and of course goes up) and can do a lot of different jobs, last time I bought argon/CO2 mix for it I think it was about $40....the gas is not too expenisive unless you do a bone head move like I've done and leave it on over night and return to an empty tank the next morning (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) TIG is very expensive and usually for more precise jobs (start at about 1200 bucks and then you need accessories) Stick welding is kinda dirty (lots of splatters), MIG is usually a little nicer with the weld qualities and TIG can produce show qaulity welds that you'd like to brag about (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) |
stock93 |
Jan 19 2006, 03:52 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
If you buy a mig, I'd go with a 170 minimum. Even though most everything on our cars is sheet you will find other things to weld once you have the setup. I have a 130 mig myself and wish I had bought one with more power. I have maxed it out on several occasions. I've even bused out the old stick welder on occasion because my mig just doesn't have enough. If you're absolutely sure sheet metal work is all you're ever going to do then the 135 is fine. I would say you probably wouldn't have any problem building a rotisserie with it but probably anything thicker and you will be wanting a larger one.
John |
sk8kat1 |
Jan 19 2006, 04:53 PM
170 huh ... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) if you go that big does that mean you need to up grade the electrical service ? or at what point is that nessisarry?
Rand |
Jan 19 2006, 04:58 PM
How thick of metal do you want to weld?
If 914 sheet metal, then a 110 powered unit will do fine. If you want to weld 1/4" plate, then you need 220 power. If you have 220 power and can afford a 220 welder, go that route because you'll have more options in the future. If you are on a budget and mostly need to weld sheet metal (18 gauge, 14 gauge....) then you could get by with a cheap 110v gasless flux-core setup. Flux-core is cheap and simple and easy and works great.... just spatters and makes dirtier welds than a nicer MIG unit with gas. But if you get a good quality weld it will be plenty strong and you can clean it up. How thick do you need to weld? What is your budget? |
Mueller |
depends on the max amperage of the welder....higher amperage, the closer to the outlet you need to be or use thicker and higher rated extension cords.....if you can easily access your 220v clothes drier or A/C outlet or have a 220v outlet in your garage, the 220v welder offers a few advantages (more effiecient and in theory use less electricity for lower bills) |
sk8kat1 |
Jan 19 2006, 06:56 PM
mostly biuld a rotiss .. 914 sheet metal .. the engman long support( 16 ga) .... prob let my friends use for there cars -- 1948 chevy truck and a 1946 pontiac
sk8kat1 |
Jan 19 2006, 06:59 PM
oh and the 4-600 range --
Lo-Fi Version | Time is now: 8th May 2024 - 09:20 PM |
