Another l-Jet Idle Question.., Need daignosis... |
jim_hoyland |
Jan 22 2006, 10:05 PM
Get that VIN ? Group: Members Posts: 9,277 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Idle was set to 1,000 when warm. Whenever I'm slowing down, like when you come to a stop light, the idle hangs at about 1,600. If I release the clutch slightly while stopped, the idle drops right back to 1,000.
My mechanic thinks its the air flow sensor. The AAR has been replaced, all hoses are attached; and, the car runs fine otherwise. What causes the idle to hang ? Is there an easy fix ? or id further inspection required ? Any help will be appreciated, Jim |
Jan 22 2006, 11:45 PM
check to make sure your clutch cableis not wrapped around the accel cable right at the front of the tunnel...it happens..ask me how I know...
You come to a stop light, push in the clutch and the revs go up... let it out and they go down....hhmmmm Or vacuum leak. Rich |
Lo-Fi Version | Time is now: 9th May 2024 - 11:44 AM |
