Opinions wanted: Handling changes, if I |
Jan 23 2006, 09:02 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yes, it will benefit the fact that it will be harder for you to spin the rear tires, which is plenty gud in a v8 914 as you don't want to spin the rear while you're in anything BUT a straight line ... as for the overall balance, a large difference in tiresize rear/front will throw off your otherwise good 50/50 balance of the car. with much bigger tires in the rear you will add massive understeer in corners. you *can* compensate for that with bigger torsion bars and a BIG sway bar. it's all in the (corner) balance. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Andy |
Jan 23 2006, 09:04 PM
Pirelli hasn't made that size in 15 years! if you got those tires "new" make sure they're still soft as they must have been sitting on someones shelf for over a decade ... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif) |
Dr. Roger |
Jan 23 2006, 09:05 PM
i'm sorry, i didn't mean wider rubber in the rear, i mean wider stance via spacers in the rear.... whoops. |
Jan 23 2006, 09:08 PM
wider stance through spacers won't give you more traction. if balanced with the front (bigger torsion bars, large sway bar) a wider track *will* improve handling ... the wider the better, *if* balanced with the front ... mueller mentioned scotts race car. it actually has a wider track in the *FRONT* ... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Andy |
Lo-Fi Version | Time is now: 30th May 2024 - 11:20 AM |
