915 trans swap, What will I need? |
ewdysar |
Jan 25 2006, 02:06 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Given the premise that I want to put a 915 into my '75 914, what will I need to address? The R&P is flipped, flywheel and clutch are already handled. What are your recommendations for the following:
1. shifter/linkage 2. clutch cable 3. axles 4. trans mounts Anything else? I just spent 2 hours using search here on the club, and I don't have any consise aswers yet. Thanks in advance, Eric |
Aaron Cox |
Jan 25 2006, 02:14 PM
if it still has the 911 nose cone on it, you can make a hanger taht also serves as a base for the linkage pivot.
clutch (go hyrdaulic?) or ive seen people use the stock pulley on its side mounted on the trans.... or you can go WEVO |
drgchapman |
Jan 25 2006, 02:17 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
I am in the process of converting a 915 to mount to a 3.2 to go into my new a/xer. All arrows point to WEVO products. http://www.wevo.com/
Hayden Burville is the owner, great guy, great products. I have Jeff Gamroth from Rothsport doing my tranny conversion, he recommended WEVO immediately. He also down played the Velios conversion kit, as have others. I'm installing the side shift kit, gate shifter kit, bearing retainer, speedo block off, I'm going with the WEVO shifter that mounts on 915 shift tower as well as his shift linkage parts. I'll likely use the WEVO tranny mounts as well, they are semi-solid. Total cost is in the neighborhood of $6,000.00. You'll also need to convert the CV's to mate to the 915. In addition I'm also installing the Quaife LSD during the R&P flip. Good luck, Gary |
914-8 |
Jan 25 2006, 02:19 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
What pressure plate and clutch disc are you using?
neo914-6 |
Jan 25 2006, 02:20 PM
search Patrick Motorsports...
neo914-6 |
search Patrick Motorsports and Bobby Hart...
Aaron Cox |
Jan 25 2006, 02:24 PM
these are what i was looking for.
not very complicated geometry... (IMG:http://www.914world.com/bbs2/uploads/post-2-1134786164.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1134786227.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1134786286.jpg) |
Aaron Cox |
Jan 25 2006, 02:40 PM
again swine!
914-8 |
Jan 25 2006, 02:53 PM
did the search, for some reason it didn't work.
looked at the Patrick Motorsports site, are you using the carbon/kevlar clutch disc and Centerforce pp kit that is around $830? Is that better than the Renegade HD kit? What's the current hot setup for high torque V8 conversions using 915? |
ewdysar |
Jan 25 2006, 03:03 PM
The current hot set-up for high torque v8's is a 930, the 915 is falling from grace. People are starting to use G50's but that's a lot of work/$$$.
I've got the Renegade/Kennedy HD clutch/flywheel/plate setup. Are there issues hooking up the WEVO kit to a sideshift chassis (different shift rods)? Eric |
drgchapman |
Jan 25 2006, 03:53 PM
Small amount of fab work, minor mods. The linkage needs to be extended some amount that is individual to each car. |
Britain Smith |
Jan 25 2006, 04:56 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Hmmm, WEVO! The quality is top notch, you would be hard pressed to find something better...IMHO!
(IMG:http://www.britainsmith.com/Porsche/Yeaman/images/128_2843_JPG.jpg) (IMG:http://www.britainsmith.com/Porsche/Yeaman/images/128_2852_JPG.jpg) Superlite Flywheel (11lbs)!! (IMG:http://www.britainsmith.com/Porsche/Yeaman/images/128_2832_JPG.jpg) Shifter in my car: (IMG:http://www.britainsmith.com/Porsche/912Project/Assembly/images/IMG_0104_jpg.jpg) One piece bearing retainer in my tranny. (IMG:http://www.britainsmith.com/Porsche/912Project/Transmission/images/170_0019_JPG.jpg) |
wbergtho |
Jan 25 2006, 05:42 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Check out Kennedy Engineered products for an Stage 2 aluminum RSR style 915 pressure plate and consider using a stock disc with it. This combo is supposed to be good to almost 500 HP. I had it on my car until I blew my 915 up and swapped it for a 930 box....Oh goody...something even more expensive to blow up? (I hope not!)
Bill |
ewdysar |
Jan 26 2006, 01:03 PM
Bump... Anything else?
Eric |
nocones |
Jan 26 2006, 03:09 PM
Sportscar lunatic Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
I would not, I repeat NOT recommend using the linkage setup shown in the photos posted by Aaron. Aside from small differences in mounting it is the same one as on my car. Nothing but a hassle. This is Rod Simpsons design and while it will work, it provides very poor shift feel. If you go this route (I believe it is the least expensive option) then pay close attention to alignment of all pivots. Lets just say it takes some fiddling with it to get it "right".
I'm still considering the cable setup from renegades, simply for the lower cost. Ideally though I will be installing the WEVO parts. My 2 cents... |
nine14cats |
Jan 26 2006, 05:40 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
How much of a price difference between the cable shift and the wevo?
I have a 2nd flipped 915 gearbox sitting in my parts rack. I had the full blown WEVO box that I sold to Andy S. and with me pouring in money on the 911 I'm a little strapped for cash on my 914-6. I was looking at the cable setups and was curious. Thanks, Bill P. |
ewdysar |
Jan 26 2006, 05:50 PM
WEVO sideshift kit, $2k.
Rengade cable shifter, around $800 - 1K. I don't know how I feel about the cable shifter box on the tunnel... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Eric |
nine14cats |
Jan 26 2006, 05:57 PM
I never liked the position of the shifter in my 914...maybe having a cable shift tower in a position of my choosing would be better... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
I didn't know that the cable shift units were that low. I had the full blown treatment on my WEVO box....which included paying a shop to put in the WEVO tailshift internals. Not having to get into the box would be significantly cheaper. Anyone shifted one before? What kind of feel? Bill P. |
ewdysar |
Jan 26 2006, 06:15 PM
Thanks for mentioning that. I've always felt that the shifter was just a little too far forward. This could be the chance to shift that back a little, maybe build a console between the seats with better storage, maybe cup holders too... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Eric |
soloracer |
Jan 26 2006, 09:59 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
What was wrong with the Vellios kit? My car came with a 915 transmission converted to side shifter by a Vellios kit. Don't get me wrong, I believe that the WEVO product is as good as all the feedback says it is and if I didn't already have a converted 915 I would consider the WEVO conversion. But since I have the Vellios already I'm reluctant to just toss it out without some specific problems being presented. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:53 AM |
