What transmission would you reccomend for a 2.4 |
grantsfo |
Jan 28 2006, 11:29 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
What transmission would you reccomend for 2.4 six conversion. What would be realistic price for the transmission you reccomend.
Aaron Cox |
Jan 29 2006, 04:46 PM
clay and i have the same box (cept 5th) ROFL...
JWest |
Jan 29 2006, 07:08 PM
Clay, did you think about using the pedal assembly from a '74 or later (but pre-power brake) 911 that has the helper spring on the clutch pedal? |
brant |
Jan 30 2006, 11:12 AM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the 2nd gear strategy is good for more than 150hp. I base this on Allen Johnsen's personal car that he drives in around 8 races a year. I believe that he dyno'd his 2.2/4 at 205hp. And thats a 4cylinder so its a lot more torque than a /6 He told me that he has 3 years on his tranny without having ever opened it. He told me that he won't build a 2nd gear into 1st postition over 200hp. and on a normal 901 with a normal unuseable 1st gear, he won't install the tranny into a race car with over 250hp.... puts 915's into everything over 250hp because its more cost effective over the course of 1 or 2 seasons combined. heck I used to run 150hp through my 901 with the 4 cylinder (somewhere close to it anyways) and only rebuilt the tranny twice in about 12 years. I agree that the 901 has its limits, its just not so fragile that it is impossible to use it if treated right. brant |
ClayPerrine |
Jan 30 2006, 11:16 AM
Life's been good to me so far..... Group: Admin Posts: 15,484 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It could make a difference. I may give it a try before I go to the hydraulic clutch setup like Rich Johnson has on his tranny. |
Brian Mifsud |
Jan 30 2006, 03:05 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Very informative thread guys.. thanks for the hard numbers.
Lo-Fi Version | Time is now: 26th May 2024 - 06:06 PM |
