Cam gear on crank, Proper method for removal/ |
KevinP |
Jan 28 2006, 03:43 PM
Member Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 |
I need to remove the cam gear off the crank so that I can have some balance work done on a rebuild. I usually just have the machine shop do it but I elected to do the removal this time. I've put on several before but never removed one. Should it just be heated and use a gear puller or both? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Thanks for any input gang! Kevin |
Mark Henry |
Jan 28 2006, 03:49 PM
Let the machine shop do it, you need a press.
Do not heat. |
KevinP |
Jan 28 2006, 03:53 PM
Thanks Mark,
Will do! Kevin |
Cap'n Krusty |
Jan 28 2006, 04:48 PM
While we're at it, NEVER USE A GEAR PULLER to remove the cam drive gear! EVER! It'kk mash the teeth under the puller arms and you'll need a new gear. Every time. The Cap'n
Lo-Fi Version | Time is now: 19th May 2024 - 05:27 AM |
