What do I need?, bare metal |
Hammy |
Feb 2 2006, 03:52 PM
I don't know anything about painting and such, keep that in mind (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Some areas on my car are bare metal, where paint is scratched off from previous dents or is peeling off, from what I assume is a cheap PO paint job. Also my rear trunk is bare metal now, but if I want to save everything from rusting, what do I use? Some sort of primer, but what? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I'm not worried about cosmetics at this point. |
Brew |
Feb 2 2006, 03:55 PM
That's Captain Moron to you! Group: Members Posts: 391 Joined: 5-August 05 From: Colorado Springs Member No.: 4,546 |
Self-etching primer, followed by a coat of primer-sealer to keep the moisture out. Both should be available in rattle-can at you favorite local paint supply house.
Allan |
Feb 2 2006, 03:57 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) SEM is a good self ething primer. Should be available at your local automotive paint supplier. |
Brett W |
Feb 2 2006, 05:38 PM
Sherwin Williams makes this Kick ASS, zinc chromate acid etching primer. It is a two part catalyzed primer. Great for covering bare steel and fiberglass. Lay down a coat if it and then throw some regular polyurethane primer surfacer. DOn't leave any primer exposed to the elements long it will soak up water.
914GT |
Feb 2 2006, 06:19 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
An exception to this are two-part epoxy primers, which are waterproof and hold up pretty much indefinitely. But they don't come in a spray can and it's expensive. The stuff I use - R-M Diamont Epoxy - probably is not even available in California because of environmental laws.
Lo-Fi Version | Time is now: 13th May 2024 - 09:51 PM |
