Starter replacement, any hints |
Trevorg7 |
Feb 4 2006, 03:21 PM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
I am going to replace my starter. The top bolt seems to be in a tough position to remove.
Any suggestions? T |
Aaron Cox |
Feb 4 2006, 03:33 PM
its a pita....
have a second person hold the bolt while you take the nut off.... |
SLITS |
Feb 4 2006, 03:35 PM
it's not that hard....it unscrews from the engine side of the tin and if you have a stock starter, the bolt is held in place unless you push it towards the tranny.
I just put a box end wrench on the starter side (if it's a non-stock starter) and unscrew the nut from the engine side. |
Chris Pincetich |
Search and you shall find!
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Sir Andy posted some awesome pictures, with arrow, on removing the top bolt from inside the engine bay without removing any tin. To put it back in, I taped the nut to the wrench until it threaded... search mini-starter if the first try doesn't work. |
SLITS |
Feb 4 2006, 03:37 PM
Disclaimer....this statement was made by an engineer with absolutely no mechanical ability at all........... (IMG:http://www.914world.com/bbs2/html/emoticons/Yack.gif) |
Trevorg7 |
Feb 4 2006, 05:46 PM
Thanks for the help. Once I figured out it was a bolt and not just a nut on top it went very quickly.
New mini-starter installed. Same as this one starter T |
URY914 |
Feb 4 2006, 06:55 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Hey that my thread! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Glad it helped you out. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Paul |
Trevorg7 |
Feb 4 2006, 09:38 PM
It is! and it did!
Doesnt the starter have a cool sounds too? Thx. T |
Lo-Fi Version | Time is now: 9th June 2024 - 06:16 PM |
