starting my 914-6 restoration, parts and autenticity questions |
freezing14 |
Feb 6 2006, 09:26 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
Ok my -6 just got delivered,, just need papers to cross the border , but as i was looking at it,, i noticed that i there is no sway bars,, i taught they all came with it,, even the hole under the tank are not done,, i have confirm the tub number and they all match ??? any one knows??
, i will also need a left side heat exchanger,, if any one has just one!!,, the longs are good but the whole floor is gone as well as the front firewall, the trunk floor is good too,, the other question is the shift linkage,, are they different from both early and late 4,, the car had AC and it will be taken off, and put for sale or trade for -6 bits |
Bleyseng |
Feb 6 2006, 09:31 AM
naw, they didn't all come with sway bars. You can source a SS heat exchanger nowdays.
early 4 shift linkage is different from a six although its not quite as good as a side shifter. |
Mark Henry |
Feb 6 2006, 09:34 AM
brant |
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
none of the -6 came with sways.
Sways started in 73 and all of the -6's were done by then. I agree with Geoff regarding the shift linkage. 3 differenty styles were made: early 4, late 4, and -6 brant |
davep |
Feb 6 2006, 09:35 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
freezing14 |
Feb 6 2006, 09:37 AM
other question,, i have to change the whole floor pan, from the front trunk ( because of the AC) under the tank (bad) and the whole cab, , can i put the car on a rotisserie or does the floor give rigidity to the shell,, there is a small hell hole,, should I fix that first and then put door frame brackets and then the floor,, what about the front firewall in which order should i go , i guess long, firewall and floor ,, but when can i hang the car??
davep |
Feb 6 2006, 09:43 AM
You should put the car on a rotisserie, but only do a section at a time. Being a unibody every section is important to the rigidity. You have to be careful with the welding also so that warping does not cause problems.
Mark Henry |
Feb 6 2006, 09:46 AM
I'd do the longs and get my door gaps right before I put it on the BBQ.
freezing14 |
Feb 6 2006, 10:01 AM
I should get the car this week hopefully,, and then i will be out for a week,, but i will dissasemble the rest of the car , fix the long and then put it on the rotisserie and start,, I will have some pics then, beeing a real -6 I will try to document the restoration as much as i can, i have a parts car already so that will help, anyone with only one heat exchanger ( passenger) for sale?? for some reason 1 is perfect and the other so gone that even then pipe is gone
Lo-Fi Version | Time is now: 8th May 2024 - 06:13 PM |
