1.7 into a 2.0, am I asking for trouble? |
warrenporsche |
Feb 6 2006, 04:45 PM
Member Group: Members Posts: 52 Joined: 22-January 06 From: Winston, GA Member No.: 5,456 |
I took the engine out of my 72 1.7 yesterday to begin my restoraton project. If I want a 2.0 do I need different injectors to go with the 2.0 heads? what about pushrods? same length? can my d-jet run the 2.0 or am I gonna have to replace all that stuff with L-Jet ( insane $$ since the engine ran when I took it out)
Thanks for any pointers warrenpoirsche |
tat2dphreak |
Feb 6 2006, 04:51 PM
I think you'll want the 2.0 brain, TPS, and TB, injectors should be fine though... 2.0 was still Djet...
74914LE |
Feb 6 2006, 04:54 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Here is a link to a site that you can visit for many of your answers:
http://members.rennlist.com/pbanders/DJetP...m#Compatibility Basically it works like this- Either keep the 1.7 ltr. stock with F.I., or upgrade to a completely different 2.0 ltr. set up. When it is all said and done, you will be better off to purchase a complet unit that has been running "recently". Just my $.02 Good luck! |
ClayPerrine |
Feb 6 2006, 06:10 PM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just changing the heads, pistons and cylinders does not make it a 2.0.
The crank and rods are different to increase the stroke. I would suggest using the factory 2.0 injection setup on your engine. If you want, I can show you a 2.0 setup. I have one in my attic. I live in Hurst, but I am currently out of town. I will be home on the weekend. |
Lo-Fi Version | Time is now: 8th May 2024 - 12:43 PM |
