| tdsmoonchild |
Mar 12 2006, 05:53 PM
Terry ![]() ![]() Group: Members Posts: 197 Joined: 18-January 06 From: Duncanville,TX Member No.: 5,431 |
I live at wheatland and freeman st. in Duncanville. My shop is on N. Main ST. in Duncanville, just north of I-20. PM me if you ever want to stop by and show me what a car looks like all put together and running! |
| dakotaewing |
Mar 13 2006, 08:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region
(IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) Can I just some by sometime? It's going to be a long time before my car is running... I doing a compete paint up job as well.... |
| tdsmoonchild |
Mar 13 2006, 09:09 PM
PM sent dakotaewing...
| tdsmoonchild |
Mar 23 2006, 09:01 PM
New toys for the shop!
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche051.jpg) This one took some doing. My shop didn't have 220v and I'm too cheap to hire an electrician. Shop is an old building and the service panel only had one space available for another breaker. Well you need two breakers for the 220v. To make matters worse, the breakers I needed are no longer made anymore! Had to source the two big amp, obsolete breakers, use them to feed an add-on service panel, run my 220v circuit for the compressor off of the new add-on panel, plus replace the one circuit for my overhead lighting that I had to remove to make space for the two big-amp, obsolete breakers. Major PITA. All done while original service was hot! Good news is it all works, looks professionally done, and nothing caught fire! |
| tdsmoonchild |
Mar 23 2006, 09:03 PM
And behind door number two.......
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche050.jpg) Didn't realize purchase of the shielding gas cylinder was so expensive..... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
| tdsmoonchild |
Mar 25 2006, 01:40 PM
Lots of rust repair to be done! My plan is to put the tub on a rotisserie, but then I have this:
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche062.jpg) another look: (IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche063.jpg) |
| tdsmoonchild |
Mar 25 2006, 01:44 PM
Trunk floor looks like this:
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche065.jpg) and: (IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche064.jpg) So looks like I need to replace whole trunk pan. Anyone know of sources for this? Thought I would just use "Grasshopper" method for the bumper mounting point. Any suggestions? |
| Brando |
Mar 25 2006, 02:13 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Also looks like they used a gas welder to put the pieces together... without rod. That's a fugly weld job (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif)
| Sideways |
Mar 25 2006, 08:33 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 18-October 05 From: Calgary, AB, Canada Member No.: 4,969 |
Restoration Design has the rear part of the trunk floor.. http://www.restoration-design.com/index.html |
| tdsmoonchild |
Mar 27 2006, 09:49 AM
Maybe I need more, like the whole trunk. Some of the other areas are very pitted.
| tdsmoonchild |
Mar 28 2006, 10:14 AM
| tdsmoonchild |
Mar 30 2006, 07:37 AM
Ok, so I've fabricated the piece for the rear bumper mounting point, but I need suggestions on protective coatings. Do I coat it before welding it? Weld-through primer, metal ready? Or after with something like POR15? Help me out.
| rjames |
Apr 4 2006, 01:23 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,485 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
For similar repairs I've used Metal Ready followed by Por15 and am happy with the restults so far...
| tdsmoonchild |
Apr 4 2006, 03:55 PM
While I'm waiting on a fender section to finish repair of the back bumper mounting point, I decided to start building the world's cheapest (and ugliest) rotisserie. It started out like this:
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche070.jpg) Big pile of old metal tubing in a field behind the shop. |
| tdsmoonchild |
Apr 4 2006, 03:59 PM
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche072.jpg)
started putting pieces together. |
| tdsmoonchild |
Apr 4 2006, 04:00 PM
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche085.jpg)
Pipe notching by hand with an angle grinder is tedious work. |
| tdsmoonchild |
Apr 4 2006, 04:01 PM
| tdsmoonchild |
Apr 4 2006, 04:02 PM
| tdsmoonchild |
Jul 6 2006, 07:46 AM
sorry no update for so long.....
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche104.jpg) took some time off for shop improvements |
| tdsmoonchild |
Jul 6 2006, 07:49 AM
finally finished the world's cheapest (and ugliest) rotisserie
(IMG:http://i9.photobucket.com/albums/a92/tdsmoonchild/porsche097.jpg) |
Lo-Fi Version | Time is now: 7th November 2026 - 08:29 PM |
