Rubber Fuel Hose..., "Do not use as fuel injection hose" ?? |
yarin |
Feb 10 2006, 04:30 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I got my goody box from Summit Racing.
I'm checking out this 3/8" and 5/16" "fuel line & emission control hose" and noticed at the bottom of the sticker it says "Do not use as fuel injection hose" link here at summit Does that mean I can't use this from the fuel rail to the injectors? OR does it mean I can't use it as fuel line from the tank, pump, etc? "This Hysunite fuel line/emission control hose from Goodyear is designed especially for gasohol and later carbureted vehicle applications with high under-the-hood temperatures. The cover is oil and gasoline-resistant and withstands exposure to fuel, vapor, moisture, and high heat up to 250 degrees F. The Chemigum rubber tube is specially compounded to resist gasoline, oil, diesel, and other fuels, while the high-strength synthetic textile reinforcement brings minimum burst to 175 psi. This hose meets SAE specification J30R7." (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 12:59 AM |
