3rd and 5th Gear Swap |
Van914 |
Feb 12 2006, 09:37 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Does anyone have the instructions for this swap.
Do you change both the imput shaft and main shaft gears? Trying to get ready for the April DE Thanks Van |
groot |
Feb 12 2006, 10:13 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Yes, you must change both gears... all gears are matched and should always be run together.
KenH |
Feb 12 2006, 10:29 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
The gears are swaped from one shaft to the other.
So yes, you have to remove both shafts and gear stacks and the rearrange the gears. Should inspect the Synco's at the same time. Ken |
Aaron Cox |
Feb 12 2006, 10:40 AM
All there is to it. flip shafts and swap positions....
A 'Q' or 'S' gear will compliment your new box as a slightly shorter 4th gear.... |
Van914 |
Feb 12 2006, 02:46 PM
Arron,
Yes I have a S Gear for 4th. some one had a picture on a thread one on hear but I can't find it. Thanks Van |
Aaron Cox |
Feb 12 2006, 02:52 PM
thats precisely what i have....
slivel |
Feb 12 2006, 03:00 PM
Old car....... older driver Group: Members Posts: 510 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
On the topic of swapping gears, does anyone know if it causes any problems when you have the opposite thrust factor applied to the transmission internals. Since the gears are helical cut (not straight cut) they produce some thrust vector and this would be reversed when swapping shafts.
Steve |
KenH |
Feb 12 2006, 04:07 PM
I checked with Jerry Woods about the thrust issue and he said had not seen any problems from the swap.
Arron - I am making the same change to my tranny and was going to put a Z in for 5th. Any comments?? Ken |
KenH |
Feb 12 2006, 04:10 PM
Oh - also changing 2nd to GA. Our AX tracks usually red-line 2nd just before a turn, thought a GA would keep me pulling.
ken |
crresind |
Feb 12 2006, 04:16 PM
Newbie Group: Members Posts: 13 Joined: 8-June 04 From: Oceanside, California Member No.: 2,175 Region Association: Southern California |
As KenH said, there does not seem to be a problem with swapping gears. Keep in mind that the trans can be used to decelerate as well as accelerate. There has been some duscussion among trans 'experts' but there is no diffinitive answer against the practice. One common swap is to take a ZD from 5th and swap to 3rd, giving a KA. I have several race cars using this swap. Five years so far and no problems.
crresind |
Feb 12 2006, 04:18 PM
Steve are you still using the 901/911/914 behind that 3.2?
slivel |
Feb 12 2006, 05:00 PM
Yes, and it's now a 3.4 twin plug. I'm running AFMSX gears. |
Aaron Cox |
Feb 12 2006, 08:49 PM
ken - is this a 4 banger?
a GA is a bit taller than an F.... so youll have a taller second, a shorter third (S or Q for 4th) and a Z which is a slighty shorter 5th.... so youll have a bigger 1-2 gap, a WAYYYY shorter 2-3..... 3-4 is a tad shorter 4-5 is a bit longer, but still shorter than a ZD so youll have a close ratio 3 speed and a slight overdrive for streetability |
brant |
Feb 12 2006, 09:05 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I had no problem using a KA (or K/L as I've heard it called) flipped for about 5 years on a race car
brant |
ottox914 |
Feb 12 2006, 11:07 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
In the classics section there is a great thread on auto-x transmissions that goes over alot of this stuff. I'm considering a 5th to 3rd swap for the next rebuild, and possibly swapping the 4th gears, one shaft to the other, to make a cheep close ratio 1-4 set up, keeping 5th tall for the highway to and from the events. Anyone done this one? Waddya think? Is the jump from 4th to 5th just way to much, or do-able?
KenH |
Feb 13 2006, 12:18 AM
Arron - 4 cyl 2.0 track car. GA is to try and stay in 2nd for AX.
On the big track never use 2nd (except out of the pits) racing only 3, 4, 5. Thunderhill has the longest single section of the tracks up here and now when I Tach out of 4th and drop to 5th the car "mushes down". So my plan is to try short 3-4-5 gears to see if I can just red-line in 5th at the end of the longest section. Ken |
JWest |
Feb 13 2006, 08:48 AM
You can't do that, unfortunately, because one gear is splined to the shaft and the other is on a bearing with a syncro, so they can't be swapped directly. The 3rd to 5th works becase they flip and invert, but you could not just flip 5th or 3rd in there own position either. |
Aaron Cox |
Feb 13 2006, 10:27 AM
your 3-4 will be nice... but you need a wayy shorter 5th to stay in the powerband and not mush down.... if you go KA S id say want an X for 5th.... linda limits your highway cruising..... ask trekkor for a ride in his M S X box.... |
KenH |
Feb 13 2006, 10:31 AM
I made a mistake. I did mean X.
Thanks for the reply and sorry I confused the issue. Ken |
Lo-Fi Version | Time is now: 11th June 2024 - 03:14 PM |
