914-6 Conversion Shift Linkage Question, Straight or Bent? Let the opinions fly |
John |
Feb 13 2006, 11:45 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I am about to fabricate some rear shift linkages for some -6 conversions, and have been seeing a slight bend in the rear shift rod.
When I did the conversion 13+ years ago, it was common(?) for the shift rod to be absolutely straight as is confirmed by my existing shift rod. We purchased the straight rod from a vendor in CA 13 or 14 years ago possibly from Galen Bieker and it has worked well for both the original 901 side-shifter as well as the current 915 (vellios) transmission. My main questions are: 1. Is there a need for the shift rod to have a slight bend? 2. Does the slight bend help minimize binding in the bushings? 3. Is the bend to avoid bumping into the bottom of the engine case? 4. What is the location of the slight bend(s)? 5. Is there 2 slight bends or is there just one? Pics would be very helpful. Otherwise, I'll continue to make up straight ones and verify that they work with my existing 914-6 conversion. Thanks for your input. |
porschetub |
Oct 31 2016, 12:03 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My shifter rod had a bend around 150 mm from the end of the gearbox shifting was ok then worse ,I know my 911 mounts are shit and have gone soft,removed the rod and the end literally fell of due to a crappy brazed weld.
New mounts on the way and plan to deal to the rod,don't think my gearbox can handle to many more bad shifts (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) . Maybe I will pm Perry for his master plan?,I don't think straight is right for a sideshifter. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:22 AM |
