914-6 Conversion Shift Linkage Question, Straight or Bent? Let the opinions fly |
John |
Feb 13 2006, 11:45 AM
I am about to fabricate some rear shift linkages for some -6 conversions, and have been seeing a slight bend in the rear shift rod.
When I did the conversion 13+ years ago, it was common(?) for the shift rod to be absolutely straight as is confirmed by my existing shift rod. We purchased the straight rod from a vendor in CA 13 or 14 years ago possibly from Galen Bieker and it has worked well for both the original 901 side-shifter as well as the current 915 (vellios) transmission. My main questions are: 1. Is there a need for the shift rod to have a slight bend? 2. Does the slight bend help minimize binding in the bushings? 3. Is the bend to avoid bumping into the bottom of the engine case? 4. What is the location of the slight bend(s)? 5. Is there 2 slight bends or is there just one? Pics would be very helpful. Otherwise, I'll continue to make up straight ones and verify that they work with my existing 914-6 conversion. Thanks for your input. |
horizontally-opposed |
Oct 31 2016, 03:28 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Have a 73 side-shift car with a 2.2 six.
John Holleran, who did the conversion and has done a dozen or so, mentioned he built the shift rod by using the forward shaft from a 911 (the one that goes into the interior) and the back of a 914 shift rod. It looks straight to these eyes, and the welding is beautiful. I was worried about the shifting, as my 914 was one of the better shifting 901s I had tried (or more likely just familiar). It shifts better now than it did. YMMV! |
Lo-Fi Version | Time is now: 20th May 2024 - 03:01 AM |
