914-6 Conversion Shift Linkage Question, Straight or Bent? Let the opinions fly |
John |
Feb 13 2006, 11:45 AM
I am about to fabricate some rear shift linkages for some -6 conversions, and have been seeing a slight bend in the rear shift rod.
When I did the conversion 13+ years ago, it was common(?) for the shift rod to be absolutely straight as is confirmed by my existing shift rod. We purchased the straight rod from a vendor in CA 13 or 14 years ago possibly from Galen Bieker and it has worked well for both the original 901 side-shifter as well as the current 915 (vellios) transmission. My main questions are: 1. Is there a need for the shift rod to have a slight bend? 2. Does the slight bend help minimize binding in the bushings? 3. Is the bend to avoid bumping into the bottom of the engine case? 4. What is the location of the slight bend(s)? 5. Is there 2 slight bends or is there just one? Pics would be very helpful. Otherwise, I'll continue to make up straight ones and verify that they work with my existing 914-6 conversion. Thanks for your input. |
dimitri |
Feb 15 2006, 03:16 PM
dimitri Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 |
Looking at my original 914-6 and the 74 6 conversion, both with later
side shifter transmissions and stock original heat exchangers, the shift rod has to be straightened with this combination of parts, because the heater section of the 914-6 reaches right up under the oill return tubes. This makes it necessary to run the shift rod on top of the heat exchanger. On the other hand if your exhaust system does not reach into this area and when attached to the engine you have a clear view/path from the exit on the firewall to the shift point, rebending is not necessary. Dimitri |
Lo-Fi Version | Time is now: 20th May 2024 - 02:58 AM |
