Engine stand questions |
Richard Casto |
Feb 15 2006, 03:55 PM
I am dismantling two Type IV engines that was part of the parts stash that came with my car when I purchased it. I am at the point that I would like to put the engine on an engine stand. Also at some point I expect to have a 3.2 six on a stand. I have never used one before and I need some tips…
1. I was looking at buying a Harbor Freight version. If I remember correctly they have 750, 1000 and 2000 lbs versions. Anyone have experience with these? The 1000 is only a bit more than the 750 version, but the 2000 version is about twice as much as the 2000. Any reason to not just by the 1000 lbs version? http://www.harborfreight.com/cpi/ctaf/disp...temnumber=32916 2. I assume that an adapter like they sell on PP is needed. http://www.pelicanparts.com/catalog/images...and-mainely.jpg The PP adapter seems a bit pricy at $155? Alternatives? Other sources? Anyone want to sell me one cheap? 3. How in the hell do you lift the engine up onto the stand once it is mounted to the adapter? Do you use an engine lift, crib up stuff and jack it up (sounds risky), two or three strong friends lift it into place, any of the above? One of the two is to the point that it is just a case that needs to be split and I can lift that. The other is a long block and I can’t lift that by myself. Thanks, Richard |
Cap'n Krusty |
Feb 15 2006, 03:58 PM
All things considered, you NEED either that adapter or the real engine stand "yoke". The Cap'n
Richard Casto |
Feb 15 2006, 04:06 PM
PP sells the real yoke for about $180 or so and the adapter for about $155 or so. The price diff is not that large. Should I just get the yoke instead? Are pretty much all engine stand mounts universal (ID of mount that yoke would go into?) Still thinking both adapter and yoke are price. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Al Meredith |
Feb 15 2006, 08:09 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Look in your JCWhitney book in the same box with the engine stands is a VW adapter, I've one for years for TY4 engines . I do not use it for 911 engines...to much at stake
tat2dphreak |
Feb 15 2006, 08:19 PM
cbperformance has them too... |
Cap'n Krusty |
Feb 15 2006, 08:28 PM
The yoke would be better, but it may not fit in your stand very well. If you have plans for a big 6, then you want the yoke with a lot of curved arms, not just the 4 on the lighter weight version. The Cap'n |
Richard Casto |
Feb 16 2006, 08:53 AM
Thanks for the tips guys. I will look at the other sources you mentioned. With the "six" rebuild probably at least a year or more away, I may do something cheap with respects to my type 4 teardown and then invest in a nicer yoke later on if I can't find something I like now.
Any comments regarding my question about the best way to get the engine on/off the stand once it is mounted to the yoke? If an engine lift is the preferred method (really don't want a lift in my garage if I can avoid it) then what is the pickup points/method used for both a type 4 and 911? |
Richard Casto |
Feb 16 2006, 04:02 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
Come on, someone has some tips on how to get engine up onto the engine stand. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
sixnotfour |
Feb 16 2006, 04:16 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I use an affordable chinese method; 2 Guy
usaully cost about 2 beers (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
jflash914 |
Feb 16 2006, 08:04 PM
Member Group: Members Posts: 80 Joined: 24-February 05 From: binghamton,ny Member No.: 3,652 |
2 guys can usually get the motor up in the stand. Me and my son just lifted a six motor onto the stand that was fully dressed, just make sure you have the back of the stand up against a wall so it does not roll back.
SLITS |
Feb 16 2006, 08:06 PM
Forklift..... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Richard Casto |
Feb 16 2006, 08:39 PM
ok, two guy method it is. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Thanks for the tip on the issue with the stand rolling away/falling over. |
Carrera916 |
Feb 16 2006, 08:53 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
Well....here's one crazy idea that I grew up doing this....
My father has his own race engine rebuilding projects going on in his home basement and at times he's alone to do stuff around. He came up with an idea of using an old trashed input tranny shaft, drill a 20mm hole through the ceiling rafters (in the garage of course), stick the input shaft in the hole, hook up the "come along" cable and ratch'n up the engine off the floor then swing the stand over to where the yoke is aligned...push the engine toward the stand and pronto, you're done...unratchet the come along and then go on with your business... works very well everytime.... j |
Richard Casto |
Feb 16 2006, 09:05 PM
Jerry, Makes sense, but how did he hook onto the engine? I can see that if you have the yoke attached that you can use that on one end, but what about the other? Or did he just have some type of sling under the entire thing? |
Lo-Fi Version | Time is now: 4th May 2024 - 05:19 AM |
