> Rust repair Questions, Welding, cutting, POR15ing, etc.
rjames
post Feb 18 2006, 05:56 PM
Post #41
I'm made of metal
Rust treating, killing, etc, and just want to get some input before I get to crazy with the MIG.
Here are some questions:
I have some floor pan issues. Are the holes too big just to try and fill? The following photo is from the driverside, under the seat after the tar has been removed, and I've grinded down to bare metal. Should I advertise for someone who's cutting up a car to cut this pieces out for me, or should I just go buy some sheet metal and make a patch knowing it won't really match, but can at least be made to 'line up'?
rjames   Rust repair Questions   Feb 18 2006, 05:56 PM
Hammy   You can buy new replacement floor pans. Also any ...   Feb 18 2006, 06:01 PM
scotty b   do yourself a favor and get a new pan section. Tha...   Feb 18 2006, 06:02 PM
rjames   Next set of questions: Do I just cut the jack pla...   Feb 18 2006, 06:05 PM
scotty b   Cut it out, treat inside and replace with a new pi...   Feb 18 2006, 06:11 PM
scotty b   you need to do something with the upper left porti...   Feb 18 2006, 06:16 PM
rjames     Feb 18 2006, 06:23 PM
rjames
  Feb 18 2006, 06:35 PM
sk8kat1   OSPHO?   Feb 18 2006, 06:39 PM
elocke   I just measured a piece that I trimmed off a Resto...   Feb 18 2006, 06:57 PM
rjames   I was looking at the floor plan that restoration d...   Feb 18 2006, 06:58 PM
Bartlett 914   The seat mounts are extra. They are not on the sit...   Feb 18 2006, 07:03 PM
rjames
  Feb 18 2006, 07:28 PM
scotty b   Sorry about the delay, I had a dinner date last ni...   Feb 19 2006, 07:13 AM
elocke   Hey; that was my 100th post ...   Feb 19 2006, 09:14 AM
rmital     Feb 19 2006, 10:08 AM
vesnyder   I bought my drivers side floor pan from Stoddards...   Feb 19 2006, 10:23 AM
abearauto   http://www.914world.com/bbs2/...   Feb 19 2006, 10:59 AM
elocke   Woops...I just reread this and realized I misread ...   Feb 19 2006, 01:08 PM
elocke   Here's that 1st layer installed.   Feb 19 2006, 01:10 PM
elocke   Then the bottom layer with flange to meet the oute...   Feb 19 2006, 01:12 PM
elocke   This piece is the end of the outer rocker, shaped ...   Feb 19 2006, 01:16 PM
elocke   This piece overlaps the outer rocker, as will the ...   Feb 19 2006, 01:22 PM
elocke   Outer layer installation.   Feb 19 2006, 01:23 PM
elocke   I didn't make the parts with the dents for the...   Feb 19 2006, 01:27 PM
rjames   Ed- Fantastic job you're doing!! Ho...   Feb 20 2006, 12:15 AM
rjames   Figured I'd attach a couple of pictures of the...   Feb 20 2006, 12:37 AM
rjames   'nother. Stupid camera phone isn't the be...   Feb 20 2006, 12:39 AM
elocke   Thanks...this was the pinnacle of the rust repair ...   Feb 20 2006, 09:25 AM
turbo914v8   I have these parts put together as one. I purchase...   Feb 20 2006, 11:50 AM
rjames
  Feb 21 2006, 01:19 AM
elocke   I basically copied the factory layout. When I cut...   Feb 21 2006, 09:04 AM
lotus_65   assuming the following: repairs have been *reason...   Feb 21 2006, 10:13 AM
rjames   My guesses: If there is rust still present, then t...   Feb 21 2006, 01:00 PM
rjames
  Feb 26 2006, 03:27 PM
rjames   'nother   Feb 26 2006, 03:28 PM
rjames   ..   Feb 26 2006, 03:28 PM
rjames   I need to cut this piece out due to too many holes...   Feb 26 2006, 03:30 PM
rjames   Also a couple of more questions for anyone and eve...   Feb 26 2006, 03:36 PM
scotty b   drill out the spot welds with a good spot weld cut...   Feb 26 2006, 05:57 PM
rjames   drill out the spot welds with a good spot weld cu...   Feb 27 2006, 01:46 AM
rjames   Pretty clean!   Feb 27 2006, 01:46 AM
rjames   hell holes to be repaired...   Feb 27 2006, 01:47 AM
porsha916   Thats quite a project, building your own rust free...   Feb 27 2006, 07:31 PM
rjames   Yeah, I got inspired by looking at all of the othe...   Feb 27 2006, 10:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:29 AM
