subaru engine choice, subaru conversion question |
ModPR3 |
Feb 21 2006, 08:59 PM
Member Group: Members Posts: 96 Joined: 7-February 06 From: Orange County, CA Member No.: 5,544 |
ok this is for the subie powered guys. i think im going to go with the subaru engine and renegade hybrids conversion kit but dont know which engine to use. i want something reliable and daily drivable not looking for crazy power, probably a max of 250hp turbo powered or 180hp n/a powered. so what do i use. a 2.5 n/a motor or 2.0t turbo motor. i would perfer to use the turbo motor but will go n/a if i have to. if i go with the turbo motor, about how much and who can make a turbo header/manifold and exhust for me that will not require cutting the origional 914 sheetmetal. also if i go with the turbo motor do i have enough room to run a heater system. thanks for the help.
Mueller |
Feb 21 2006, 09:16 PM
if using the Renegade kit, your smart choice is to ask "them" which motor to use since that'll dictate whether or not the kit and the engine you pick is compatible (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
turbo motors generally cost more up front and are a little harder to tune...how much work can you do yourself? |
Porcharu |
Feb 21 2006, 09:33 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
Take a look here for a turbo exhaust that should work for a 914 - it should fit easy with a front mounted radiator. Of course you will blow the 901 trans to bits with a turbo 2.5 Suby (see Steve put on fireproof suit.) (IMG:http://www.914world.com/bbs2/html/emoticons/hitfan[1].gif) I think this setup might even work on a mid-radiator car. Outback motors |
ModPR3 |
Feb 21 2006, 09:39 PM
lol...fireproof suit. but yes i would stick with the subaru 2.0 usdm turbo motor and stay under 280 hp and keep the tq low too. im interested in this mid radiator setup what does this involve any info on this would be great. since this car would be my daily driver the mid radiator setup may give me more room in the front trunk. |
ModPR3 |
Feb 21 2006, 09:47 PM
my goal would be to do what you did and use the usdm 2.0 turbo motor. its not so much that im on a budget but the more expensive the cost for the conversion the longer i will have to wait to do it and the sooner the better. i can do any wrenching but cant weld at all. so any custom exhust work will have to be sent out. do you have an estimate for cost and parts wise for the exhust system to work with my 914. thank. |
Porcharu |
Feb 21 2006, 11:12 PM
The mid-car radiator was pioneered here on 914club.not-a-club by not-a-club-member Scott Thatcher. I am doing a follow up to his idea and am also using the Subaru transmission (try the search function and look up "Scott Thatcher" and "Subaru transmission possibility" for more info than you may want.) See my blog for progress. I hope to have it ready by summer. Maybe not running but all bolted in and ready to go. I would really like to make it to WCC 06' in the car. |
mrdezyne |
Feb 22 2006, 11:20 AM
Now on larger rolling jack stands! Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 |
I ended up going with the N/A 2.5 for simplicity sake. Turbo is always an option later but I figured I would have my hands full just trying to get an N/A mounted and running correctly without having to worry about the turbo stuff. Heat is another consideration with the turbo engine.
Most guys turn the intake around so that the TB is facing the front. I'm going to just cut clearance through the trunk and run my CAI through there, instant heat shield. Kennedy Engineering Products also makes the adapter plate and flywheel for $440 + flywheel core. I have read before that you want a SOHC instead of the DOHC version. I'll try to find the reasoning behind that and post it. Or if someone else can answer that one. Shop carpart.com for your engine, you can find just about anything there and maybe find a good deal. I got my 2004 EJ25 with 14K and wire harness for $1100...... Attached image(s) |
Crazyhippy |
Feb 22 2006, 01:26 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
If you are going to go through the trouble of doing a swap, why limit your HP? I'd do the turbo 2L. It's a DOHC motor as opposed to the Na 2.5's and it makes more reliable HP.
Only downside is not sure you can do the mid radiator. BJH |
Hydra |
Feb 23 2006, 06:33 AM
Quia nominor LEO Group: Members Posts: 162 Joined: 11-December 04 Member No.: 3,261 |
I went with an N/A 2.0l dohc engine (ej20), it's a weird enginefor the US since it was never sold on the US market, i got my engine for 200$. i'm also mating it to a suby front wheel drive tranny, which also doesn't exist in the US (75$), and a mid mounted rad setup. The engine puts out 190 bhp at the flywheel (up from 150bhp stock), with minor tweeks.
As said before if you'll be going with the 901 tranny, forget the about the turbo (or the tranny). Nice to have another suby conversion on the forum. Best of luck Nick |
soloracer |
Feb 23 2006, 10:22 AM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
Another subie choice would be the 3.3 flat six out of the SVX (EG33). You would get the best of both worlds - reliable N/A power and close to the 250 hp that you want. Engines can be bought for under $1000. Just a thought.
brer |
Feb 23 2006, 11:01 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
the four cam 2.5 is known for its head sealing problems among other things.
and the spark plugs cost $60. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) ask me how i know. |
WRX914 |
Feb 23 2006, 11:07 AM
2.5 WRX STI hybrid powered beast Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
True dat! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
plymouth37 |
Feb 23 2006, 11:19 AM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Hi ModPR3 My Name is Dana, I work at Renegade Hybrids and am one of the designers of the subie kit. I am sure you have seen my subie 914 around the site. bare metal, flares... anyway I have sold a lot of these kits and every one of them is getting a 2.0 turbo from a 2002 -2004 wrx. don't be scared of turbos! hooking up a turbo is just plumbing. To say that I abuse my transaxle would be an understatement and I just have a tired old 914 tranny with NOTHING done to it, my tranny is holding up just fine!. If you have any more questions regarding the subaru engine conversion or 914s in general, give me a call at 1-866-498-2421 or check out turbo914.com.
jsteele22 |
Feb 24 2006, 12:57 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Yeah, I'm toying with that one. I've been reading up on it at subaru-svx.net, and this engine is _very_ impressive. Forged crank and pistons, seven bearings. These things just don't die. And what's kinda nice (for swappers) is that the tranny in the SVX seems somewhat failure-prone. So pulled engines and parts cars are fairly easy to come by. I've found a couple in the $500 range. I'm also curious about the EZ30, Subie's newer flat six. Its lighter and shorter front to back, but I don't know if it fits in a 914. I *think* it's abot 2" wider than an EJ25, and I gather there isn't a full 2" to spare. |
Mueller |
Feb 24 2006, 01:08 PM
can you share how many kits have been sold? 5, 10 or more?? |
lapuwali |
Feb 24 2006, 01:43 PM
Curious: does anyone have specs on this engine? How much does it weigh? How different is it from the 3.0 six used in the Legacy? |
soloracer |
Feb 24 2006, 07:07 PM
From another website:
"This is a 6 cylinder 3.3 liter, opposed engine, 265 lbs. bare longblock weight, 230hp from the factory" The Subaru 3.0 six cylinder is probably a more desirable engine as I believe it is shorter in length than the EG33. However, finding a 3.0 is difficult and when you do find one they tend to be much more money. I was originally thinking that an EG33 would be a nice fit for someone who was considering a Porsche 3.2 but couldn't justify the cost of a Porsche 3.2 |
Crazyhippy |
Feb 25 2006, 04:43 PM
I know of one for sure (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) BJH |
Lo-Fi Version | Time is now: 8th June 2024 - 08:30 AM |
