this is probably a dumb question..., installing targa top seals |
double-a |
Feb 24 2006, 09:18 AM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
i'm reassembling my targa top after paint, and i have a few questions:
1. the metal strips holding the side seals are curved, why? 2. which way does the curve face, to the inside or outside of the car? 3. these strips are different at each end. one end is notched a little, with a small tab protruding. why is this, and which direction does this notch go, forward facing or rear facing? i guess i should've taken a picture when i took it apart... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) ~a |
Root_Werks |
Feb 24 2006, 10:04 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
So you have learned that the pieces are not "A" symetrical now.
Are we talking only about the strips on the top itself or the whole car? If its the whole car, then the straight ones have the little notch that hangs down go to the inside of the car and down (towards bottom). The two that fit to the winshield are pretty easy as they have an angle to them and easily only fit on one side or another. Hope that helps. |
double-a |
Feb 24 2006, 10:10 AM
the pieces in question are the metal srips that screw into the left and right side of the targa top. they are curved slightly, and are different at each end. the targa top seals mount to these strips, and the side windows, when rolled up, seal against this rubber.
i'm curious as to which end goes forward. i'm also curious why they're curved when the side windows are not. that wouldn't appear to make a good seal, but what do i know. ~a |
mikey |
Feb 24 2006, 01:06 PM
Member Group: Members Posts: 423 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None |
It should be apparent which one strip goes on which side. Just line them up. They'll only fit one side.
If the channel has been dented down to hold the rubber secure (both sides of mine were) bend the dent back up so the rubber will go in easier. Get some black butyl tape at a glass store, or find a friend with a bit left over from a windshield installation, and put a thin strip along the piece before you screw it in. This prevents wind noise, I think. Also the screws are wierd little screws with flat bottoms, not pointy. See my blog for my experience putting in the rubber seal. Let me know if you have any questions. I just installed this seal on my car recently and it's pretty fresh in my memory. Mike |
double-a |
Feb 24 2006, 01:17 PM
thanks mike, that's good info. i think i've got it now. just couldn't figure why the two ends of the metal strips are different. doesn't seem to be a reason for it.
~a |
davesprinkle |
Feb 24 2006, 02:00 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Hi double-a,
I did this part of my assembly last weekend and had the same questions you do. After some time scratching my head and several installations in various orientations, I've come to this conclusion: You have no doubt noted that the channel is cut differently at each end -- one end is cut roughly at 90 degrees, while the other end is angled at approximately 45 degrees. Orient the channel so that the angled end is at the top of the targa bar. Then, install the rubber seal similarly; that is, so that the angled end is at the top. This orientation will nicely align the angled end of the seal with the angled end of the channel. This orientation also positions the seal so that it meets the angle of the seal on the targa top, sorta like a miter joint on a picture frame. By the way, I found a 3M product at my auto-paint supply place that is the exact match of that rubbery compound on the back of the channel. (Sorry, don't remember the product name or number off the top of my head. I can get it this evening after work.) Sorta like butyl rubber, but not nearly as sticky. It came in a string about 1/8" in diameter. $11 for a box holding way more than I'll ever use. |
Porsche Rescue |
Feb 24 2006, 02:37 PM
3M stuff is called Strip Calk, 08578. Old timers like me call it dum-dum. Also used behind the metal strip which screws to the targa bar which holds the seal. All sorts of other creative uses.
double-a |
Feb 24 2006, 02:50 PM
no, no no... i'm talking about the seal and associated hardware mounted to the top itself.
~a |
Lo-Fi Version | Time is now: 8th June 2024 - 09:06 AM |
