914-6 engine question, up to which size of cylinder can i go |
Heeltoe914 |
Feb 24 2006, 02:01 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
I have a set of 6 cyl, 2.0L heads already cut for 2.7 P & C. with new guides and and some new vavles. that I was going to be putting on Ebay but 914 guys first.Drop me a line for pics.
lapuwali |
Chris, rather than continue to incorrectly answer these questions, just refer people to Anderson's book and keep quiet. All the details are there, they've been researched, and everyone messing with 911 engines should have a copy. You're only adding to the confusion.
alpha434 |
Feb 24 2006, 02:04 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Go get Bruce Anderson's books. All of them.
That better? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
michel richard |
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
There is 2.0 counterweighted crank, was used in all engines except the T. Same crank was used in the 2.2. Another crank, counterwieghted, was used throughout the 2.4 and 2.7 production run. It is the same blank of a crank as that used for the 2.0 and 2.2, but with the rod journals machined a little smaller and a little further away from the crank's axis, resulting in a longer stroke.
You should really get Anderson's book, it is fun to read and has pictures of all these parts. |
propricer |
Feb 24 2006, 02:10 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
If you want easy hp, I have a set of 2L S P&C's in very good condition for less than a grand.
thesey914 |
Feb 24 2006, 02:26 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I know some 914-6 owners who have kept their oringinal 6 and then fitted a larger 6. Might be the best bet as you have non-counter-weighted crank cast-iron cylinders. Might work out uneconomical to rebuild it to say 'S' spec
freezing14 |
Feb 24 2006, 02:48 PM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
hi there mr andersons book is already on order, should get it in a week or so,, the reason here is that i want to rebuild the 2.0 to run and look original,, I still have 6 month to a year to rebuild the engine , so i will be oportunistic in finding stuff to rebuild, i will be rebuilding my self for most of it ,,, (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) when i have the book (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) so if heads need to be machined, thats out ,, of whatever else need to be done by some machinst thats out too,, only bolt on
thesey914 |
Feb 24 2006, 02:56 PM
Reccomend Wayne Dempseys rebuild your 911 engine how to book also. V interesting
freezing14 |
Feb 24 2006, 03:01 PM
here is the exact title of the book ordered
How to Rebuild and Modify Porsche 911 Engines 1966-1989 - 1 @ $32.12 is it the right one |
J P Stein |
Feb 24 2006, 05:33 PM
NOT Get the book & read it. |
thesey914 |
Feb 25 2006, 03:14 AM
Yes that is the one. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:25 PM |
