Exhausting Ideas, Sorry for the Pun |
skeates |
Feb 24 2006, 08:57 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
So has anybody thought about using the exhaust header wrap stuff on the 914's humble heat exchangers to try and reduce heat in the engine compartment? Just curious if it would be worth it.
Peace, Steven |
Aaron Cox |
Feb 24 2006, 08:59 PM
that stuff retains moisture.... and the HE's already rust out....
McMark |
Feb 24 2006, 09:06 PM
You engine shouldn't overheat. If it is something is wrong. Fix the real problem.
Allan |
Feb 24 2006, 09:10 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) If you are having an overheat problem it's probably due to poor cooling of the motor. Sheilding the H/E's won't help much... |
skeates |
Feb 24 2006, 09:23 PM
I was just wondering as I figured that they would improve the efficiency in which the heat exchangers were able to heat the air being pumped into the cabin rather than overheating.
URY914 |
Feb 24 2006, 09:47 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You are right there but only do it on SS boxes. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:10 PM |
