| seanery |
Sep 6 2003, 05:01 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
This looks interesting (melts at 720 degrees F) so not a super high temp fix, but quick and it looked fairly strong.
Here is their webpage Any thoughts, opinions, experiences? |
| elmonte |
Sep 6 2003, 05:17 PM
Member ![]() ![]() Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
As seen on TV not a good sign. Too good to be true?
| ChrisReale |
Sep 6 2003, 05:57 PM
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I'be used a similar product with ok results. Was not car related.
| Katmanken |
Sep 6 2003, 07:37 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Seanery,
Sounds like the aluminum weld rod I bought at Sears Tool store. Had a cracked aluminum oil pan in my mower and used it to patch it. Ground the crack out and heated it up with a oxy-acetylene torch. Stuff just dabs in and hardens. Looks a lot like an aluminum weld and it was harder than hell when I had to dremel off some excess. Met you at Maumee (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/wink.gif) |
| Katmanken |
Sep 6 2003, 07:41 PM
Oh yeah, that propane torch wouldn't have cut it. Aluminum is a hell of a heat sink so you will need more power.
(IMG:style_emoticons/default/laugh.gif) |
| mskala |
Sep 6 2003, 08:48 PM
R ![]() ![]() ![]() Group: Members Posts: 1,949 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
A few years ago a friend and I split a $45 batch of the Alumaloy
rods. I'm not a materials guy but I'm sure if you find rods that melt at that temp somewhere else cheaper it's going to be the same stuff. The infomercial shows a bunch of weird cases that would be much more of a pain in the ass than would other solutions. If you try to patch something big like a canoe or extension ladder you will be noticably older before you could get that thing to 750F. However, it does work and is useful for small projects. I almost made a tool cart, and made up my fire extinguisher bracket pretty easily. If you are careful, you can use something hotter like propylene to make the job easier. |
| rick 918-S |
Sep 7 2003, 12:23 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,279 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I bought a similar product at Northern tools. I attempted to repair an aluminum front shroud on my 1954 Austin Healey 100-4.
I tried propane and map gas. I couldn't get it hot enough to get a good bond. I have gas welded everything an consider myself proficient. Bottled gas is not hot enough for the base metal. Atleast .060 material anyway. I tried some diamond plate I have and was able to join two pieces with map gas. Good luck. |
| ChrisFoley |
Sep 7 2003, 08:17 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
It's probably the same stuff I buy at the local welding supply houses, called Aladdin 3in1. It's basically white metal (pot metal) which is a high zinc aluminum alloy. I only use it to repair white metal parts with my TIG welder. Its very difficult to use with the TIG because the zinc likes to vaporize due to the arc temperature, and the whole part can melt from heat buildup if not careful. I do it this way because I can weld some otherwise unrepairable pieces.
| Katmanken |
Sep 7 2003, 08:51 AM
The Sears product is a "Self Fluxing Aluminum Rod " 1/8 " diameter and is made(repackaged?) by US Forge. I believe it was less than $10.00 for 12 or so rods.
Very little info on the package and none on how to use. Claims that the material can be used "to wearface aluminum" "good color match for aluminum" and "low working temperature." Also, "the flux is in the rod". Worked great for my application. Only problem is it flows vey freely when hot and I had trouble building up a thick section. Then again, I'm not the worlds greatest welder. Web research claims it isn't a solder and you need to crimp the end of partially used rods to save the flux. I'd use it again. (IMG:style_emoticons/default/smile.gif) |
| John Kelly |
Sep 7 2003, 10:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
I think that stuff is actually for aluminum brazing, not welding. Brazing does not penetrate the base metal. Check out Kent White's site for lots of good information:
www.tinmantech.com John www.ghiaspecialties.com |
| seanery |
Sep 7 2003, 10:28 AM
yeah, I think you're right john.
| Rusty |
Sep 7 2003, 07:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,993 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States
Pot metal?
Could this stuff be used to fix broken door handles? -Rusty (IMG:style_emoticons/default/smoke.gif) |
| ChrisFoley |
Sep 7 2003, 09:20 PM
QUOTE(Lawrence @ Sep 7 2003, 09:40 PM) Pot metal? Could this stuff be used to fix broken door handles? -Rusty (IMG:style_emoticons/default/smoke.gif) Probably not worth it. The chrome will be destroyed. Just the same, I have one I plan to try repairing for the hell of it. |
| Aaron Cox |
Sep 7 2003, 09:57 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
QUOTE(elmonte @ Sep 6 2003, 04:17 PM) As seen on TV not a good sign. Too good to be true? not sold in stores because its a piec of Shit... LOL ... I got the idea cuz i smoked a lotta pot.... (IMG:style_emoticons/default/laugh.gif) (reference from comedian pablo francisco) |
Lo-Fi Version | Time is now: 9th June 2026 - 12:02 AM |
