Turn Signals Don't Work |
TINCAN914 |
Feb 25 2006, 11:36 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
Checked the fuses, and and replaced the bulbs.
Any suggestions? The wire colors are hard to see, since the Po had the trunk painted and didn't cover the wires..... |
Elliot_Cannon |
Feb 25 2006, 11:47 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Put your arm outside and point it up means right turn. Point you arm straight out means left turn. Point your arm down means slow down and stop. Hope this helps.
Cheers, Elliot |
TINCAN914 |
Feb 26 2006, 12:24 AM
Oh great, that fix's it..Thanks so do those packages fly themselves? And this from a pilot.. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
grasshopper |
Feb 26 2006, 09:29 AM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
relay??? do you hear the clicking???
nick mironov |
Feb 26 2006, 11:07 AM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
I had the same problem. Turns out that the contacts for the left and right signals inside the sterring column mechanism wore out and could no longer make a good contact. I could not repair them directly, so I jumpered the turn signal cotnacts to the marker light contacts, which are right next to the turn signal contacts, and cut the wires to the marker lights.
The turn signals work now using the contacts intended for the marker lights. However, I can not light up the marker lights any more, but that is not a problem for me. |
Tobra |
Feb 26 2006, 12:49 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Could it be the relay? Fixed my problems
Turn signal relay thread Did they work and then stop, or never work? |
TINCAN914 |
Feb 26 2006, 12:51 PM
Clicking on the right, but not the left. THey were wroking limited when I picked the car up, but the bulb was real faded. I replaced them all. |
TINCAN914 |
Feb 26 2006, 12:52 PM
See reply above.. Thanks for th link Tobra... Will check the contact on the steering and the relay... |
Aaron Cox |
laquer thinner works great at getting paint off the wires....
TINCAN914 |
Feb 26 2006, 12:56 PM
The painter got some on the terminals as well. I will try that.
Aaron Cox |
Feb 26 2006, 12:59 PM
wire brush the terminals... |
TINCAN914 |
Feb 26 2006, 01:16 PM
Thanks mehartie.. (IMG:http://www.914world.com/bbs2/html/emoticons/piratenanner.gif) Pirate Glossary lol...http://homepage.mac.com/crabola/PirateGlossary/Menu22.html |
Lo-Fi Version | Time is now: 8th June 2024 - 12:20 PM |
