Aluminum Threshold plates, What did you use to attach? |
computers4kids |
Feb 26 2006, 11:00 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I've bought a set of new aftermarket aluminum threshold plates to replace my black plastic ones. (no attachment harware is sold with these). What have you used to attach them in lieu of the black plastic rivets?--stainless screws...rivets (what size?) I'm not to sure how good rivets will look.
Much appreciated, |
Mueller |
Feb 26 2006, 11:11 AM
I'm pretty sure the black plastic rivets are avialble, I think Demick posted a link.....I think alum, rivets would look better, available with a tool at most all hardware places.....you need to measure the hole diameter (use a drill bit) and you need to know the total thickness of the plate and the sheetmetal to which it'll attach to (I'd say 1/8" max)....a rivet with a "reach" of 1/4" to 3/8" should work fine.
boxstr |
Feb 26 2006, 11:13 AM
I just installed some of those great looking Alu. threshold plates with pop rivets. They work fine and unless you are a CW then I don't think it matters. Be sure to lay down a coat of wax before installing , so that any H2O will slide out.
CCLINTHRESHOLDER |
rhodyguy |
Feb 26 2006, 11:17 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
little, stainless, philips head screws. what the cheap bastards at vw should have used in the first place.
k |
Porsche Rescue |
Feb 26 2006, 11:28 AM
I wanted close to original for the early cars which had aluminum sill plates. I found some white plastic rivets at ACE hardware. They press in by hand and hold very well. Not exactly like the factory NLA white rivets, but pretty close. Easy to remove without damaging the plates.
tracks914 |
Feb 26 2006, 04:43 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I was able to find some white plastic rivits that were very close to the originals. They look pretty good too.
tracks914 |
Feb 26 2006, 04:49 PM
pix
tracks914 |
Feb 26 2006, 04:50 PM
nuther one
computers4kids |
Feb 26 2006, 07:05 PM
Lots of great ideas. Does anyone have a picture of using screws or stainless rivets to hold a threshold plate down--I'm visual? Both offer definite advantages and disadvantages.
Thanks |
Lo-Fi Version | Time is now: 8th June 2024 - 09:18 PM |
