KUMHO 710s arrived today, What's the AX skinny? |
Joseph Mills |
Feb 27 2006, 08:08 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
They're handsome devils... so full of promise... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Last year I finished the season on some two year old Victoracers that had lost their "sticky" sometime last summer, so I'm REALLY looking forward to getting these new tires out on an AX course. Last year I noticed some of the miata guys running the 710s where wetting their tires with spray bottles between runs. BS?... or do these tires really benefit from this? Your verdict please. I ran 26# front & 28# rear with my Victoracers last year. Do the 710s like higher or lower tire pressures? Oh... also... are you running a bit of toe in or toe out? Thank you teener brethren. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
URY914 |
Feb 27 2006, 08:44 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,319 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
What were they wetting the tires with?
I doubt it was water. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Joseph Mills |
Feb 27 2006, 08:47 PM
I "thought" it was water. Spray adhesive? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
GaroldShaffer |
Feb 27 2006, 09:48 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Water. I seen a lot of guys doing this also last year. I have 710s I finished my season with. They got hot but I never understood why you would need to "cool" them down between runs? Maybe my region is different, but you usually waited about 10 - 15 min between runs depending on the amount of cars running. Also we only ran on blacktop, maybe cement is different for tire temps?
I tried the water thing and didn't notice any difference one way or another. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Trekkor |
Feb 27 2006, 11:33 PM
Exactly!! Let the air out after every run to keep them there. Yes, it's water. For cooling. I don't do it. There's plenty of time between runs, so they won't overheat. They "hook up" immediately, unlike the Hoosiers which need a run to get hot. You will like them. they seem to last well, too. I have 2 a/x's and twelve hours of track time on mine. (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif) KT |
Trekkor |
Feb 27 2006, 11:40 PM
I forgot my little picture (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Look at the sidewalls under load...nice and stiff! (IMG:http://www.914world.com/bbs2/html/emoticons/shocked[1].gif) On three wheels, too. KT Attached image(s) |
Trekkor |
Feb 27 2006, 11:50 PM
DanT |
Feb 27 2006, 11:52 PM
show off (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Trekkor |
Feb 27 2006, 11:55 PM
"It's still just a 914"...
DanT |
Feb 27 2006, 11:57 PM
yes indeed (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Joseph Mills |
Feb 28 2006, 12:20 AM
So you're saying that 26# & 28# is a solid starting point? And you're saying the water spray is just BS? |
Trekkor |
Feb 28 2006, 12:54 AM
Yes and Yes.
After your very first run, you will be smiling so hard it will almost hurt. KT |
Joe Ricard |
Feb 28 2006, 06:03 AM
Water is not BS
Depending on circumstances two driver car and top driver can push the Kumhos 710's to some pretty high temps. The driver od a C-stock Miata monitors temps with pyrometer. His goal is 130 150 degrees higher than that and they fall off grip. He definately is always fast. There was a Street Mod Mustang with huge 710's single driver car that barely got his tires to 120 degrees He was also several seconds back. Yes it is water. Same event(single driver) my near new Hoosiers reached 130 degrees and I felt like superman dodging cones. But that was all the temp I could muster. 29 PSI all around for the Hoosiers. So far my car does not chew up tires like crazy. I am up neck and neck with the established regional hot shoes. Don't know if it is a smoother driving style or the car is so lite sub 1900 pounds that I am not pushing the tire limit. I know driver faster (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:56 AM |
