2 Pages V < 1 2
> Drive-by-wire for dual carbs/throttle bodies???, would you run them??
rick 918-S
post Feb 28 2006, 06:17 PM
Post #21
Hey nice rack! -Celette
I'm seriouly thinking about this for the Alien. Cables Suck when their long. BMW has drive by wire in their 12 cylinder. There are duel motors that cost 850.00 bux a piece. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
This can't be hard. Were not talking about drive by RC. Although that may work too (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
davesprinkle
post Feb 28 2006, 06:26 PM
Post #22
Drive-by-wire pros:
Pro #1. Emissions. Good fuel control boils down to a problem of estimating airflow into the cylinder. If the airflow estimate is wrong, then the engine will have an undesirable A/F ratio, and emissions will suffer.
In old-fashioned systems, where the driver controls the throttle, the ECU must operate in a "reactive" mode, responding after-the-fact to throttle movements. In transient conditions, ie when the driver makes rapid throttle movements (either opening or closing), the complex dynamics of manifold filling and wall-wetting make accurate fuel-control very difficult.
In the more modern drive-by-wire systems, the ECU meters both air AND fuel into the engine. In this way, the ECU is able to avoid those unpredictable and large-magnitude throttle transients that wreak havoc with A/F ratio and emissions. In these systems, the throttle pedal is no longer a throttle-actuator, but rather a throttle-request. The ECU says: "I see you just planted the gas pedal on the carpet. I will respond by slowly opening the throttle in a manner that allows me to avoid a troublesome A/F ratio transient that might cause me to fail an EPA emissions test."
Pro #2. Torque smoothing. All drivers (racers and street drivers) like to have a linear pedal vs. torque response. A computer can easily deliver this in a drive-by-wire system. I might add that clever mechanical design can do the same with a conventional throttle system, although with less flexibility -- pulleys, levers, and/or cams are more difficult to iterate upon than is a software table.
Pro #3. Torque limiting (rev-limit, pit-lane speed limit, traction control, launch control, etc.). This is the big advantage of drive-by-wire for motorsports. In a conventional system with a driver-coupled throttle, the ECU can limit torque by ignition retard, or by spark & fuel cuts. This is effective, but in many cases is very brutal, with big torque transients that can cause potentially damaging driveline oscillation. The F1 guys, running drive-by-wire, have figured out that the smoothest way to reduce torque is by limiting the air entering the cylinder -- just close the throttle.
OK, for the Cons:
Con #1. Lousy throttle response. My own personal experience is that the Suby and in particular the Lexus DBW systems are far too aggressive at attenuating throttle transients. They feel lazy and sluggish, even dangerously slow. The engine doesn't respond on a downshift throttle blip. If you plant the throttle, the ECU will "think" for a noticeable fraction of a second before it slowly feeds in more torque. Probably good for emissions, but not so good for avoiding that SUV bearing down on you. I should point out that DBW systems don't HAVE to be so bad. The Boxster that I drove felt exactly like a cable-driven system. I've heard the same about the Corvette.
Con #2. Safety. This is fairly self-explanatory. Do you really want a complex and potentially failure-prone computer system intercepting your throttle requests? There's just something reassuring about a direct mechanical connection between the driver's foot and the throttle blade.
Con #3. Complexity. The DBW systems out there have tens if not hundreds of man-years invested in their design and validation. And for good reason -- refer to Con #2.
Con #4. $$$ All those computers, actuators, sensors, and man-years add up to a substantial cost. You can rest assured that not a single auto manufacturer would have designed DBW if not for first item in the list -- emissions.
stock93
post Feb 28 2006, 09:35 PM
Post #23
BMW uses Dual linear hall sensors in the pedal assembly. One is from .5V to 4.5V the other one is .5V to 2.0V. This differing voltage is used for plausibility. Also if the wires happen to get shorted together the different voltage readings will let it know there is a problem. They use Dual potentiometers on the throttle body. One is from .5V to 4.5V and the other is 4.5V to .5V inverse of the first one. BMW uses these on more than just there V12 now. Most of the new bmws use thottle by wire. They dont seem to have any problems with it. It makes stability control really easy by limiting the thottle opening.
John
Jake Raby
post Feb 28 2006, 10:17 PM
Post #24
Engine Surgeon
Who ever markets this had better have some SERIOUS manufacturers insurance because they will more than likely be getting their asses sued!
I did this on my dyno in 2002 and 2003 when I was doing my cooling system test work and needed a universal throttle that was fast to install and remove and while it worked well I could certainly see that there are glitches that could promote a failure that could stick the throttle at wide ass open.... Fail safes could be used, as always but even those "Fail".....
The person that does this in todays modern world of lawsuites and trigger happy attorneys is asking to get their ass handed to them.
Sorry guys, thats thr truth from the retail side of the world, and it sucks.
Vehicle manufacturers may do this as standard equipment, but they can absorb the costs related to failures without losing their homes and businesses because of one prick that can't install something correctly.....
rick 918-S
post Feb 28 2006, 10:27 PM
Post #25
I can't believe it. A simple stand alone system to move the linkage connection on a throttle body? If it fails it would surely drop to idle... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I may have to give this some thought. If I can make it work I'll sell kits like MS.. You put it together, you assume the liability... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
jsteele22
post Mar 1 2006, 11:23 AM
Post #26
While I totally agree that the system has to be made extra-safe and reliable, and that anybody who tries to sell this (or anything) had better be ready for lawsuits, it really, really isn't a very complicated system. There's only one parameter to control, its easy to measure, and it varies quite slowly compared to many other feedback systems.
In fact, DBW throttle control isn't very different from cruise control. You give an input (desired speed vs desired throttle position), the system compares this to a feedback signal (actual speed vs. actual throttle position) and the system automatically generates an appropriate control output (actuale pedal via vacuum servo vs. actuate throttle via electric servo). In fact, the only difference that I can see is that in DBW the desired input is allowed to vary a bit more quickly. This is pretty much a non-issue. The one crucial difference that worries people is that with cruise control, the mechanical linkage is still there - you can turn off the controller in an instant and go back to manual mode. But once you use cruise control, it starts to feel pretty comfortable for its intended use. I think DBW would be the same. (Most people who use it now don't even know...)
Also, I think that a lot of folks who drive 30-year old cars are already used to the idea that control over their their throttle or clutch (i.e., the cables) might possibly give out at any minute .....
2 Pages V < 1 2
- Lo-Fi Version Time is now: 11th July 2025 - 06:00 AM
