Turn Signal indicators, 2 instead of 1 |
John |
Mar 4 2006, 09:36 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Has anyone rewired a later model car to that of an early model car to get individual turn signal indiators?
The early style was wired so that each indicator light (in the tach) had one of the turn signal wires (black/white stripe or black/green stripe) and the blue/white stripe. As far as I can tell, the flasher relay is the same, but the wiring is different due to the fact that the 1974 and later cars only had the single indicator light in the tach. The 74 wiring diagram shows the indicator light wired to the blue/white stripe and ground. Is this rihgt or not. maybe I'll wire it up and find out..... |
jk76.914 |
Jul 12 2006, 07:18 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
That's right. Just like the front and rear signals. Are you adding them as well? Have you picked one? I'm using '90s vintage Saab repeaters. They look right, and they don't need a recess in the fender, just a hole.
Lo-Fi Version | Time is now: 4th May 2024 - 12:53 PM |
