Turn Signal indicators, 2 instead of 1 |
John |
Mar 4 2006, 09:36 AM
Has anyone rewired a later model car to that of an early model car to get individual turn signal indiators?
The early style was wired so that each indicator light (in the tach) had one of the turn signal wires (black/white stripe or black/green stripe) and the blue/white stripe. As far as I can tell, the flasher relay is the same, but the wiring is different due to the fact that the 1974 and later cars only had the single indicator light in the tach. The 74 wiring diagram shows the indicator light wired to the blue/white stripe and ground. Is this rihgt or not. maybe I'll wire it up and find out..... |
jim_hoyland |
Jul 12 2006, 11:18 AM
Get that VIN ? Group: Members Posts: 9,271 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The Saabs sound good; would you have the part number(s). I'll prolly order them now and do the install much later. Can they be ordered on-line ?
Thanks again, Jim |
Lo-Fi Version | Time is now: 4th May 2024 - 11:12 AM |
