Widest tire for standard wheel |
obscurity |
Mar 7 2006, 08:39 PM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I have a pretty stock 914 1.7 with steel wheels (4 1/2" I think) The tires on the car are still bias tires so they are VERY dry rotted. I think the existing tires are 165 R15 which almost nobody seems to make anymore. What is the widest tire you can put on a standard rim without it looking weird, rubbing or being unsafe?
I'm fine with a relatively stock look but a little wider never hurt either Thanks |
riverman |
Mar 7 2006, 09:11 PM
Learn As I Go Group: Members Posts: 449 Joined: 18-January 05 From: Kitchener, ON Member No.: 3,466 |
205-60's
obscurity |
Mar 7 2006, 09:18 PM
wow! 205s I never would have guessed they could be that wide but then I don't know much about tires
SGB |
Mar 7 2006, 09:19 PM
205/50 will fit, but 195/55 would be fine too....
Dave-O |
Mar 7 2006, 09:32 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Guys guys guys,
He said 4 1/2" rim. A 205 tire will fit on a 5 1/2" rim but it is even a little bit too wide for that. If you want to keep your 4 1/2 inch rims I would say run a 185-65-15. They are only rated for a minimum of a 5" rim but you're not going to find much under a 185 that will give you a decent tire selection. If you upgrade to 5 1/2" rims you can run the popular 205 size. Tire Rack options in 185-65-15 Hope this helps, |
Aaron Cox |
Mar 7 2006, 11:01 PM
where did you geet 4.5" wheels?
you ahve 5.5's im guessing. 205's fit but look retarded! stcik with a 195 sticky..... |
Dave-O |
Mar 8 2006, 12:18 AM
Early 914's came stock with a 4.5" steel wheel. To the best of my knowledge (pleae correct me if I'm wrong) the only 5 1/2" wheel avalable for early 914's was an optional alloy. This obviously changed with the later 5 1/2" "star" style steel wheel. There are lots of 4 1/2" steel wheels for 914's around but hardly anybody runs them for obvious reasons.
205's fit a 5 1/2" rim just fine. In fact most tire manufacturers (Including Hoosier) include 5 1/5 in the "acceptable" range of width for a 205 tire. As far as looking "retarded"...a large majority of 914's run a 205 tire on a 5 1/2" rims and I can't think of any that fit that description (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
bd1308 |
Mar 8 2006, 06:15 AM
aaron......
your retarded. thank you, try the beef. |
obscurity |
Mar 8 2006, 07:52 AM
I'm pretty sure they are 4 1/2" but I have not taken them off to measure. At least one of the tires has not "traditional size" list on it but claims to be for a 4-1/2"X15" wheel. Near as I can tell (from receipts) the last time this car had new tires was 1978
Bleyseng |
Mar 8 2006, 09:39 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
from your pics on the site, its a 71 but has both early and late style steel wheels on it.
Bleyseng |
Mar 8 2006, 09:40 AM
Don't tell me you bought the car from .... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
The hellhole looks pretty bad but fixable. (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) Attached image(s) |
obscurity |
Mar 8 2006, 09:48 AM
Yep I bought it from Automobile Atlanta And I spent WAY too much. The hell hole is bad but the rest of the car is in surprisingly good shape.
On that deal I really felt screwed but recently I have liked them more and you can't beat a 20 minute drive to buy that part you need right now (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
blitZ |
Mar 8 2006, 10:03 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Hey, another local teener, welcome. What part of Atlanta?
Aaron Cox |
Mar 8 2006, 12:40 PM
i spaced on the 4.5 wheel thing..... bulging sidewalls werent my thing. just a matter of opinion... 195's are great on a 5.5, 205's are most optimized on a 7" but are 'ok' on a 6 inch... just opinions (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) britt... go eat a tube steak (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
obscurity |
Mar 9 2006, 01:02 PM
I'm in southwest Atlanta. Just north of East Point. Where are you? |
blitZ |
Mar 9 2006, 01:18 PM
I'm in Snellville, think there are 6 or 8 owners in the area. We should get together sometime.
obscurity |
Mar 9 2006, 01:22 PM
yeah that would be fun. I need to get the car running well first so it makes a good showing. I'm trying to get it at least presentable so I can put it in the Georgia Tech Autoshow
obscurity |
Mar 9 2006, 07:58 PM
Well I've decided to get the 195/65 r15 (I do actually have a set of 5 1/2" wheels as it turns out) but thats not what I really wanted to talk about.
I removed all the wheels from the car and lined them up and noticed something interesting. Not a single one matchs(except size) BFGoodrich Lifesaver GT4 165sr15 Bridgestone RD108 - steel 165sr15 Michelin XZX 165sr15 Falls Metric 165 sr15 Le Havre (made in israel) 155sr15 (spare - not even steel belted) Isn't at least good practice to buy tires in pairs? Oh well hopefully tomorrow I will have at least four new ones. After that the only glaring problem with the car is hell hole rust. I guess that probably should have been first but I really just want to drive it once or twice again before I take it apart |
blitZ |
Mar 9 2006, 09:24 PM
I plan on being there, should be a good group. |
obscurity |
Mar 9 2006, 09:29 PM
I've not been to it before but it sound like it should be good. Are you bringing your car? |
Lo-Fi Version | Time is now: 8th June 2024 - 12:15 AM |
