White Headlight Trim!, ...that the DAPO painted black. |
Eric_Shea |
Mar 8 2006, 07:14 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
So I've got two sets of good headlight trim. One set is black. The other set is black too but it used to be white.
I'd 'love to get all that black paint off there so I can have some white ones (like the one's Lawrence is hoarding) for my GT project. Here's what I've tried: Goof-Off - Nope Std Paint Thinner - Nope WD-40 - Nope I'm afraid to go heavy on the solvents... what say yee?? |
bd1308 |
Mar 8 2006, 07:22 PM
carb cleaner...thats supposed to be bad on paint.
alcohol (rubbing kind) |
smooth_eddy |
Mar 8 2006, 07:24 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
how about laquor thinner?
lapuwali |
Mar 8 2006, 07:28 PM
Paint them white? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
My headlight trim is white. I didn't realize these were "special". |
Mar 8 2006, 07:29 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
try these on the BACK first
Acetone Brake cleaner Laquer thinner Most likely its painted with an enamel based rattle can paint. If so, it will come off pretty easy with the right solvent... Acetone and Brake Clean can melt plastic...but the old plastic is pretty tough and not as easy to melt as the newer blends. Laquer thinner is gonna do it, but go slow and be careful of the plastic.. Rich |
Kargeek |
Mar 8 2006, 07:46 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
Bead Blast 'em. Use fine grade glass bead. I have done this with plastics and it worked out OK. Gives a nice dull finish that with white plastic should look fine. Test on the housing's back side.
DH |
michel richard |
Mar 8 2006, 07:56 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I think the white trim was used only on the early cars, but I'm not sure when the change was made, though. |
STL914 |
Mar 8 2006, 08:32 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
The trim went to black in 73, IIRC! |
Eric_Shea |
Mar 8 2006, 09:36 PM
Thanks for all the answers...
I think white was 70 only but not sure... very hard to find and most people don't like the looks of it. James (or anyone else), if you wanna swap those ugly white trim rings on your car with a 'fine' pair of black rings, let me know... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Heavy solvents (carb, lacquer, etc.) I've been reluctant to try. I'll try them on the back and post the results. I have 80 grit in the glass bead blaster and that's what I was thinking as well. I just didn't want to fuch them up. Maybe if I lower the pressure and try that it might do it. Film at 11:00 |
MattR |
Mar 8 2006, 09:41 PM
Brake fluid???
That seems to melt paint pretty well. I dont know how it would react to the plastic. |
markb |
Mar 8 2006, 09:44 PM
I've got a broken one out at the yard I was gonna sand to see how that works. I would think sanding with finer & finer grain paper, then using plastic polish would do the job.
North Bay 914 |
Mar 8 2006, 09:56 PM
Senior Member Group: Members Posts: 509 Joined: 25-January 05 Member No.: 3,504 |
Hey Eric,
Dhdshg lergfe ;gfe; ;ier; shrouds? A dkfjel;fj fljf;l photo a;peid p;sejf...on the GTs.... Attached image(s) |
Eric_Shea |
Mar 8 2006, 10:13 PM
(currently busy with the Alta Vista translator program trying to decipher Martin's post. So far it seems to say "Who gives a shit about headlight shrouds? Take them off dumbass, like they did on the GT's) (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
North Bay 914 |
Mar 8 2006, 10:21 PM
I however did not reverse that image (now corrected)...toss the bastards, I also have white set, painted black...that of course are flaking.
Delfwjf erfh rgjeg fwff..914-6 GT ! Attached image(s) |
North Bay 914 |
Mar 8 2006, 10:31 PM
Andsedfl rtg rhug ogy frog eyed bastard rugfg...
Attached thumbnail(s) |
Eric_Shea |
Mar 8 2006, 10:33 PM
(pssssssssssst... Martin's been drinking again) (IMG:http://www.914world.com/bbs2/html/emoticons/lol3.gif)
sk8kat1 |
Mar 8 2006, 10:37 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
my white surrounds that came on my 73 were rattle caned black ---- real hot water and 2500 grit wet sanding did very well
North Bay 914 |
Mar 8 2006, 10:38 PM
NO drinky fo me.....check this killer 356. Not sure how I would remove that black paint. I think I would go brake fluid first. It MAY soften the plastic, or make it brittle. Try wiping it on the paint, but not soak it. It may break up the paint, and not harm the plastic.
Bleyseng |
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I have a white set that aren't painted black sitting in a box. I think the GT's took them off cuz they weighed soo much.
try soaking them in orange cleaner as that seems to remove everything in a day or two. |
Eric_Shea |
Mar 8 2006, 10:40 PM
Damn... there's just something about a well put together vintage Porsche racecar (what's racecar spelled backward?)
Beauty! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 04:41 PM |
