914 gas tank, Is it baffled? |
ewdysar |
Mar 9 2006, 07:55 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Is the 914 just a big hollow can? Are there any types of baffles around the fuel pickup (or drop out, as the case may be)
Thanks, Eric |
ClayPerrine |
Mar 9 2006, 07:58 PM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The only baffle is a small ring around the fuel pickup point. If you want to look, pull the filler neck on the tank. then you can look inside with a FLASHLIGHT.
Just don't use a lit match. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
bd1308 |
there's a round cylinder thing that houses the in-tank fuel filter, which acts as a baffle of sorts....
b |
Aaron Cox |
Mar 9 2006, 08:00 PM
haynes says "look in there with a torch" silly brittish 'lost in translation' (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
ewdysar |
Mar 9 2006, 08:05 PM
So I should be able to feel it with a chopstick? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) The whole torch thing has me a bit worried...
Eric |
BIGKAT_83 |
Mar 9 2006, 08:13 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
There is a ring around the stock fuel pickups and another baffle in the middle of the tank. I just cut some holes in one to add a high pressure fuel pump for my LS1 conversion.
(IMG:http://www.914world.com/bbs2/uploads/blog-1140825434.jpg) Bob |
ewdysar |
Mar 9 2006, 08:19 PM
Bigkat,
That's the reason that I was asking, not an LS1 but a MAF injection system. How'd that work out for you? The intank pump that I'm considering will mount on a 5" ring. Did you try to get the new pump pickup into the original baffle area? |
BIGKAT_83 |
Mar 9 2006, 08:35 PM
I used a stock Firebird fuel pump from the car my LS1 engine came out of. I had to extend the pickup for this pump 2" to get the pickup at the bottom of the tank. The GM pump has a internal fuel pressure regulator and a round baffle for the pump With this I had to remove the stock round baffle in the 914 tank.
This was no easy job. Bob |
SLITS |
Mar 9 2006, 10:22 PM
There is one internal baffle that goes top to bottom about 1/2 way along the length of the fuel tank. If I was really ambitious, I would crawl into the scrap bin where I threw the one I cut in half and take a picture of it.
Maybe tomorrow and maybe not! The answer is YES, the number shall be one baffle, not two, nor three, the number shall be one. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:57 AM |
