Anyone know cam specs for 2.7RS? |
nine14cats |
Mar 10 2006, 12:09 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
I'm searching for the camshalft specs for the 74-77 7R case RS 8.5:1 compression 6 cylinder.
Anyone know what it was? Thanks, Bill P. |
DanT |
Mar 10 2006, 12:11 AM
Are we building a 2.7 for the Beast? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Now you're talking (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Great AX motor. Lots of torque |
nine14cats |
Mar 10 2006, 12:16 AM
I've got a line on a completely rebuilty longblock 2.7 built to RS specs. New Mahle P's&C's. I'm actually second in line so I'll find out this weekend. So I'm doing a littly Desktop Dyno profiling. I have my old motor profile in it with the parts I put in (120/104 cams, Weber 40's, 10.5:1 JE's).
I need the cam specs to compare it. I already have a simulation with my old spec engine running JP's 9.7:1 Shasta pistons. For you vultures out there......this engine isn't advertised in EBAY or the bird board... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Bill P. |
redshift |
Mar 10 2006, 12:19 AM
I KNOW THE SPECS!
You want me to sketch it out? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) M |
DanT |
Mar 10 2006, 12:22 AM
J P Stein |
Mar 10 2006, 12:29 AM
The RS spec cams are S cams.
nine14cats |
Mar 10 2006, 01:17 AM
JP,
You runnin' S cams in your motor? (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) Bill P. |
ArtechnikA |
Mar 10 2006, 05:54 AM
you're crossing boundaries there... the "real" 2,7RS existed in '72 and '73. by '74, the RS and RSR were based on the 3,0 engine the US didn't get until 1977. (the '73-'74 RSR was a transitional phase with the 2,8 engine...) the 2,7RS was considered an evolution of the 2,4S and used the same cams. the injection pump and distributor were modified, as was static timing, and of course the pistons and cylinders were different. |
J P Stein |
Mar 10 2006, 07:00 AM
Nopers. Solex. I was talked out of S cams by Steve Weiner. At the time, the motor was a street/AX motor. S cams (per Steve) have tuning issues with carbs...mostly involving fuel reversion and they don't come on the bump till 4k or so. Considering that the majority of street driving is done on the idle circuit.....who needs the hassle. I had enuff tuning problems with the Solex grind to last me for about 6 mos. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) They come on about 500 rpm sooner also. Both E & Solex grinds give up top end for better mid range.....AX territory. S & better grinds are tha cats ass for track work, me thinks. |
0396 |
Mar 10 2006, 07:59 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Rich, You are one smart cat! Thanks for the education. Oh ya..S cams are set @ 5.2 mm (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:27 AM |
