Getting Rid of fuel injection |
saved1 |
Mar 10 2006, 09:54 AM
Newbie Group: Members Posts: 3 Joined: 7-October 05 From: Piedmont, Ca. Member No.: 4,925 |
I'm switching to dual webbers and adding a Mallory Unilite distributor with cent. and vac. advance.
Anyone out there know how to get a vac. advance tap with this setup? Thanks |
GaroldShaffer |
Mar 10 2006, 09:57 AM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
gotta ask, what's wrong with FI?
maf914 |
Mar 10 2006, 10:03 AM
The newer Webers have a port on the throttle body located on a level just below the throttle butterfly (in the closed position). If it is present there probably is a threaded plug in place that can be removed and replaced with a threaded tube fitting which allows a small rubber vaccuum hose to be slipped on and routed to the dizzy. Not all Webers have this port.
Bleyseng |
Mar 10 2006, 10:50 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Oh, while you are at it change the cam as the car will run worse, have less hp, and MPG with the Webbers and stock cam.
Fix the FI (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) |
pfierb |
Mar 10 2006, 11:18 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Don't do it unless you want the car to run rotten,trust me I speak from past experience....Webers are not the magic bullet on this car......Fix the FI |
914-8 |
Mar 10 2006, 11:21 AM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Given what you intend to do, you have a very ironic username!
jr91472 |
Mar 10 2006, 11:27 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
We could at least welcome him to the club first........ (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png) uhhhh, alot of folks run carbs here (including me) but you really should change the cam (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
ninefourteener |
Mar 10 2006, 11:32 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
Agreed..... WELCOME to the club!!!!
I run dual Solex carbs...... and a huge cam... damn thing puts out 4 times the legal limit on an emissions test.... but if you can figure out how to get around that... I say go for it. My first 914 had dual Dellortos...... they worked great as well |
Mar 10 2006, 11:36 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You dont need the vacuum advance.
Just get the correct distributor with the correct weights. (Aaron knows the model numbers) No vacuum needed. Welcome to the club. Rich |
olav |
Mar 10 2006, 11:47 AM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 05:07 PM |
