fule lines which supply, which return |
jsf322 |
Mar 10 2006, 03:47 PM
Member Group: Members Posts: 83 Joined: 1-December 05 From: Baldwin, New York Member No.: 5,220 |
I just replaced my fuel lines at the fuel tank and as I was attaching them where they go into the front firewall, I could not remember which lof the metal lines out of the fire wall is the supply line to the engine and which is the return line from the engine. Is the drivers side line the delivery or return. Thanks
robby750 |
Mar 10 2006, 05:42 PM
Senior Member Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
hose layout check here
Demick |
Mar 10 2006, 05:47 PM
Big = supply
small = return that's only if you own a 70-74 with the fuel pump under the passenger side engine shelf. Demick |
jsf322 |
Mar 10 2006, 06:22 PM
Thanks for the replies. Of course I looked at another diagram I found and hooked up the lines and now it won't start. The problem is that the diagram I looked at has the return line just the opposite from what is in the diagram in the link above. Now I have the return and supply lines backwards. I hope I did not damage the fuel pressure regulator by putting the fuel through backwards. I'll find out tommorow when I reverse the lines. Thanks for your help.
John |
Lo-Fi Version | Time is now: 7th June 2024 - 11:41 AM |
