| 75boxster |
Mar 12 2006, 01:53 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
I basically know very little about the 5-speed in my 75. What I do know is one of the ears
that are used to mount the tranny to chasis has broken. I have what I belive to be a replacement cover. Is this just a R&R deal or is there some hidden issues to swaping this piece that will suprise me when I start? Thanks guys. Tried a couple of searches but I am probably just calling this piece by the wrong name. Chris- |
| itsaporsche914 |
Mar 12 2006, 06:43 PM
Member ![]() ![]() Group: Members Posts: 169 Joined: 5-August 05 From: cave creek az. Member No.: 4,541 |
where did my post go ?
| itsaporsche914 |
Mar 12 2006, 06:46 PM
ill try again . i have the same problem as you chris . i think it can be replaced easily. im gonna try when i get the part. my mechanic said 3 hrs and 250.00 i tried to post pix of mine . didnt work . i will keep trying good luck let me know what happens
| So.Cal.914 |
Mar 12 2006, 06:54 PM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I changed the first /reverse gear in my trans, the easy part was the tail cover. I sudjest you replace the gasket. |
| itsaporsche914 |
Mar 12 2006, 07:02 PM
chris does this look familiar?
| Dave_Darling |
Mar 12 2006, 07:18 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
New gasket, new O-ring for the speedo drive shaft. I forget if there's anything else you do to seal up the speedo drive or not. Support the trans securely when you unbolt the old tail cover.
--DD |
| 75boxster |
Mar 12 2006, 09:07 PM
That looks exactly like what happened to mine.
It also took out the front motor cross bar so the whole frickin motor on the drivers side is on the gound. I am really begining to hate this car. |
Lo-Fi Version | Time is now: 18th April 2026 - 04:10 AM |
