7.5mm Fuel Injection hose, which? |
yarin |
Mar 13 2006, 10:17 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I found this site which suggests purchasing this hose from a VW dealership.
http://www.type2.com/library/fuel/fuel-lines.html I called my local VW dealership and they can order it. 5 meters of hose for $63. That comes down to $3.80/ft. The part number is N 020 281 1. The guy doesn't have any details about it though, can anyone confirm this is 7.5mm ID fuel injection hose? I also found 7.5mm hose at here: http://www.international-auto.com/pdf_files/IAP12.pdf for $2.90/foot. I called and asked what brand, they said the only marking on the hose is NBR/CR. Acceptable? Cap'n |
Mark Henry |
Mar 13 2006, 10:24 AM
That dealer hose is for late water-cooled's and is some of the best shit to use on FI, but why do you need 5 metre's of it?
I use hard lines everywhere that I can, then that hose. Make sure you use FI clamps. BTW because it's for water-cooled's it doesn't have the braided cover like the hose that came on the 914...it just looks like rubber hose. |
yarin |
Mar 13 2006, 10:42 AM
I want to use this hose from the pump to the rails and back. Also for the rails to injectors. 5/16 feels a little loose on the pump. I know I don't need injection hose after the regulator, but i would prefer to use something that is the correct diameter. I already replaced the stock plastic fuel lines with hard brake line. |
yarin |
Mar 13 2006, 04:08 PM
Argh... none of the dealerships I've called have this or can order it. The VW dealership gave me a quote on 7x3mm hose.
Sooo... can someone please give me a part # for a spool of 7.5mm fuel injection hose? Thanks |
yarin |
Mar 14 2006, 08:53 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif) anyone?
Cap'n Krusty |
Mar 14 2006, 12:34 PM
I will have a price for you soon. The Cap'n
Cap'n Krusty |
Mar 14 2006, 02:41 PM
Group buy. 914s take 14 feet of fuel line for the engine compartment, and I think that includes the lines to and from the pump. 5 meters for $32.35 plus postage. The real thing, smooth 7.5x3mm continental hose. I'd like to have 4 people buy at once. With priority mail, you're in it around 40 bucks.
The Cap'n |
Mueller |
Mar 14 2006, 02:45 PM
count me in for one chunk of that group buy..... |
Brian Mifsud |
Mar 14 2006, 02:48 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
DONSCO in San Carlos CA carries ALL of the correct German Fuel lines (high pressure and low pressure) + vacuum lines.
He caters to beetles, but has it all. |
yarin |
Mar 14 2006, 03:20 PM
How do you typically refer to hose diameter? ID x OD? What's 7.5mm x 3mm mean? 7.5mm ID and 3mm wall? That's a great price. I just ordered from international-auto though. Should be here Friday. |
Cap'n Krusty |
Mar 14 2006, 04:03 PM
7.5 mm ID, 3 mm wall thickness. Sorry I was late getting this up ..... My worldpac rep was swamped this AM and couldn't immediately clarify the pricing for me. The Cap'n |
Cap'n Krusty |
Mar 21 2006, 08:40 PM
OK. Anyone wanting to take advantage of the fuel line group buy outlined earlioe rin the thread, lemme know ASAP. I plan to ship on Thursday.
The Cap'n |
JeffBowlsby |
Mar 22 2006, 12:55 AM
914 Wiring Harnesses Group: Members Posts: 8,484 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I am in for a set Capn. I will email my address to you for payment amount due and instructions.
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
watsonrx13 |
Mar 22 2006, 06:17 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Cap'n, I'm in for a set. I've just removed my fuel tank and will be sending it out for inspection and cleaning. I would like to replace ALL rubber fuel lines in the car (not replacing the plastic lines in the center tunnel). I'm assuming that the lines that you're providing in this post is for the engine compartment only.
Can you also get the larger diameter lines that I'll need? What is the dimensions of the larger hose, dia x wall thickness x length? To recap, I would like all of the rubber fuel lines from the fuel tank to the injectors... -- Rob |
VaccaRabite |
Mar 22 2006, 07:26 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Cptn,
I'm in for this as well. Zach |
watsonrx13 |
Mar 23 2006, 06:18 PM
Any update on this??????
-- Rob |
yarin |
Mar 23 2006, 09:34 PM
You can use 3/8" and 5/16" line to the fuel tank. Cap'n is selling injection line for use on teh pressure side of the injection system. It's good stuff, but a waste of money to put it on the low pressure sure (anywhere besides between the fuel pump and pressure regulator). |
watsonrx13 |
Mar 24 2006, 05:13 AM
Thanks for clearing that up, this is the first FI 914 I've owned. Anyway, has the Cap'n responded about the group buy? -- Rob |
Lo-Fi Version | Time is now: 28th April 2024 - 02:57 PM |
