Wanna see some heads????, Mighty Spyder project heads revealed! |
messix |
Mar 14 2006, 01:52 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
jake how'd they do on the flow bench? what size valves?
they look monstrous. huge direct ports. |
alpha434 |
Mar 14 2006, 02:00 AM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Hey Jake.
Flippin awesome! What more can I say? Did you gas port the pistons? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
alpha434 |
Mar 14 2006, 03:15 AM
How well does the thermal dispersant work? Do you have any hard data for it, in comparison to aluminum?
Joe Ricard |
Mar 14 2006, 05:58 AM
Nice,
Yup thats all I can say cause I'm pretty much speachless. and that don't happen often. |
bd1308 |
Mar 14 2006, 06:43 AM
Which costs more, a 917 engine or this?
b |
Jake Raby |
Mar 14 2006, 08:21 AM
Yes I have hard data. Yes it works. All coatings are not created equally, the first 3 coatings we tried INCREASED head temps. I'm sure a 917 engine costs more than this, even a rebuild of a 4 cam does.... But the customer got a very good deal on the engine- Len and I have as much invested into it as he does! Cars and customers like this don't come along everyday and we decided to flaunt some ideas on thsis project because it was perfect to showcase our work to a group of serious people that appreciate it. The customer came to me wantinga run of the mill 2270/2316... He came over from the UK and brought pics of the car and the outline... Right away I knew he was the perfect guy for this combo! |
Mueller |
Mar 14 2006, 09:48 AM
wow...those ports are huge...I'm wondering if a variable length/area intake plenum would make a nice addition to this motor for more torque at the lower RPMs....of course in the car it's going into, I doubt it needs much help (IMG:http://www.914world.com/bbs2/html/emoticons/MDB2.gif)
dstar |
Mar 14 2006, 10:06 AM
Member Group: Members Posts: 196 Joined: 19-January 06 From: Ramstein, Germany Member No.: 5,438 Region Association: Germany |
(IMG:http://www.cycloneinjapan.com/upload/files/25/heads.JPG) Perfect turbo head! Don |
Jake Raby |
Mar 14 2006, 10:10 AM
Actually the Turbo version would be a 85+% head. This head is perfectly balanced at 80% average...
Drivability isn't a concern! The cam being used is a derivative of what Racer Chris is running in his 186HP 1800CC F prod engine! The intake valve is open .350 at BDC! It'll START to pull at 5,000 RPM... |
Slowpoke |
Mar 14 2006, 10:16 AM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
Hey Jake..... how come you spray painted all them heads??? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Seriously, does that coating holds up the the valve seats and valve faces?? Must be tough stuff. Heads look real nice! |
Jake Raby |
Mar 14 2006, 11:12 AM
It held up fine on a class 10 SCORE engine that I built last year... It did a full season including the Baja 1000 and it was still intact enough to be washed up and resused!
Mueller |
Mar 14 2006, 11:21 AM
it is pretty damn amazing that a coating can take the abuse of a combustion chamber with the heat and cooling effect of the incomming air...and then throw in the heat cycles of the parent material expanding and such....I might have to scrap my watercooled head plans (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
alpha434 |
Mar 14 2006, 12:07 PM
Yeah. Do you have problems with chipping or flaking of the coatings?
And I'm going to start PMing you a barrage of questions. |
Jake Raby |
Mar 14 2006, 12:57 PM
The coatings are just like painting a car, its all ijn surface preparation and application to get positive results.. We finally found the guys that would do this for us but not at a "cheap" rate...
Here are the pics of my pistons in the 3 Liter test engine we used for Billet head testing.. (IMG:http://www.aircooledtechnology.com/r_d_3_OH/buildup/DSCN2433.JPG) (IMG:http://www.aircooledtechnology.com/r_d_engine/small_size/100_2470.JPG) Here they are after 14,000 miles of 235HP hell raising. The coating was only scuffed just under the ring oil ring lands . This engine ONLY had .001 of piston/skirt clearance and still attained this!(IMG:http://www.aircooledtechnology.com/r_d_3_OH/teardown/First%20group%20of%20pics%20021.jpg) As for all the PMs... No need in writing them unless you plan on purchasing an engine with them employed, I don't do this for my health. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) The R&D to perfect this cost us thousands of bucks and no one gave us any assistance! |
crash914 |
Mar 14 2006, 01:40 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Jake,
You will like Lemans....nice train ride from Paris. I was there a year ago..did not get to the track though (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Lots of nice food over there...it might be more fun to rent a car to play around on the roads... have fun!! Take lots of video!! |
Jake Raby |
Mar 14 2006, 03:05 PM
The owner of the Mighty Spyder is going to let Beth and I borrow his Citroen to drive all over the UK from his place in London. I want to spend a solid 2 weeks there and about before cruising with the Porsche Club of G.B to the event in the Spyder. Beth and I already plan on hanging out at www.rabycastle.com for a day or two as well.
The owner of the car posted this earlier on the Spyderclub site "Jake doesn't know it yet, but when he gets to France in July for the Classic Le Mans series, I've booked him a once-only drive on the circuit (just one lap) so that he may test the little beauty for himself. There will be others on the track too, so not at racing speeds, just a gentle poodle.... " To say the least I'm excited! Just having a pic driving this car, with this engine at Leman will be priceless! |
grantsfo |
Mar 14 2006, 07:30 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Wow! Very nice! Take pictures. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
Randal |
Mar 14 2006, 11:18 PM
Those are nice heads Jake, but I wouldn't trade them for mine, especially since they will be bolted on the rest of your kit shortly.
Jake Raby |
Mar 15 2006, 08:08 AM
Randal, Your engine would make less power with these heads, than the ones Len prepared for you! Simply because of the "combo" |
root |
Mar 15 2006, 11:42 AM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
Jake...looks like you got a bit of chatter in the face of that exhaust port?? Hope you intend to finish cut it! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 10:01 AM |
