914-6 conversion parts ID, will 911 column parts work on a 914 |
oemexp |
Mar 15 2006, 12:52 PM
Member Group: Members Posts: 70 Joined: 5-June 05 From: Fremont, CA Member No.: 4,204 |
I have an 84 carrera dodnor car I'm using for motor, guages, struts, brakes etc. Can I use the ignition switch, wiper/signal switches on the 914? I've heard the column frame (metal that holds the electronics) is different. if so, can I use the stuff on a 914-6 frame? can the 911 frame be modified to be the same?
Mark |
ClayPerrine |
Mar 15 2006, 01:28 PM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
oemexp |
Mar 15 2006, 08:57 PM
Thanks for that. I looked at the pictures but it isn't clear to me why you removed and welded on the mount plate? Did you use the part from the 914-4 or reposition the 911 part?
Mark |
dflesburg |
Mar 15 2006, 09:02 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Geez and I thought it was more trouble than it was worth just mounting and wiring in my -6 stuff into my 74 car...
It was a PIA but I can send you the wiring for the ignition if you would like, the wipers were easy, I am still finishing the turn signal switch wiring. |
ClayPerrine |
Mar 15 2006, 10:14 PM
Mark,
The 911 column uses a completely different mounting method from the 914. So the only way to make a 914/6 column is to cut the mount pad off a 914 column and cut the mounts off the 911 column, then weld the two together. Here's a picture of the 911 column. Attached image(s) |
sechszylinder |
Mar 16 2006, 03:25 AM
Member Group: Members Posts: 247 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
Hi Mark,
have a look at my conversion. The donor was as well a 84 carrera. I've welded the original mounting plate of a 914/4 column to the carrera column. You can use the ignition switch and all other electrical components, but you have to rewire them, cause the 914/4 connectors doesn't fit to the 911 parts. Benno Attached image(s) |
Lo-Fi Version | Time is now: 10th May 2024 - 11:48 AM |
