choosing/installing front sway bar |
mikeyb33 |
Mar 15 2006, 07:32 PM
Slightly-usedbie Group: Members Posts: 84 Joined: 23-November 04 From: Santa Clara, CA Member No.: 3,168 |
This topic has doubtless been discussed tons of times already but I'm no good at using this site's Search tool...
My 914-6 (conversion) needs a front sway bar. (See attached photo, from Marina AutoX last August, if you don't believe me.) What are peoples' opinions on types/makes of sway bars, suppliers, etc? I've found different ones offered at Pelican, Automotion, etc. Also, can anyone direct me to other postings here on doing that install. would appreciate any info.! mike p.s. what about a rear sway bar? I remember seeing a posting on this a while back and it sounded like (1) a difficult install job, and (2) of questionable value without first undertaking the rather extensive job of stiffening the chassis - something I'm not ready to do to my car yet. p.p.s. Like I said: I need a sway bar! Attached image(s) |
Jeroen |
Mar 15 2006, 09:09 PM
for the front swaybar install, you'll need to remove your gas tank
if your car currently has no swaybars, you'll need to cut holes into your fenderwells (for the swaybar to fit through) weld reinforcement plates on the inside (where the tank sits) and weld u-tabs to your a-arms not a hard job really. If you have all the parts and tools, you should be able to tackle this within a days work for the rears, you need to weld in a set of mounting plates on the underside of your trunkfloor, just behind the x-brace and some reinforcement plates on top of your trunk floor (right over the mounting plates) IIRC, Engman makes these (check the resources/parts forum) you also need to replace the bolts that hold the bottom of your rear shocks to the trailing arm the bolts for a rear swaybar have a ball at the end instead of a regular hex head the droplinks of the swaybar snap over these as for choosing swaybars... for the fronts, there are quite a few options personally, I like the Tarett bars (22mm adjustable) they're only slightly more expensive than adjustable weltmeister bars and the quality is much higher they are available through the common places (including the club store - see link at the top of the page) or directly from http://www.tarett.com other options are stock (15mm non adjustable), weltmeister (19 or 22mm adjustable) or SmartRacing (different bar sizes to choose from, very nice, but pricey) for the rears, you can choose between stock or weltmeister there's lots of debate wether or not to run a rear bar depending on your rear spring rates and wether you have an LSD tranny or not I'm sure others will chime in... also try the search function for swaybar install, you should find plenty of good info and pics |
East coaster |
Mar 15 2006, 09:48 PM
Senior Member Group: Members Posts: 1,666 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Did mine a couple weeks ago.........pics here:
http://www.914world.com/bbs2/index.php?act=...f=2&t=46945&hl= |
McMark |
Mar 15 2006, 10:56 PM
IMHO, Tarett or Smart are the only way to fly. I just did a Tarett install and it only takes a couple hours.
mikeyb33 |
Mar 15 2006, 11:04 PM
thanks guys, I appreciate the info!!
mike p.s. I just looked: I do have u-brackets on my lower A-arms already, but no holes in the tub/body - time to start cuttin' & weldin'... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Trekkor |
Mar 15 2006, 11:11 PM
Andyrew |
Mar 15 2006, 11:54 PM
Your fronts liftin good.. your rear looks flat... I think you need more rear spring!
Were you getting loads of oversteer, or understeer? |
Trekkor |
Mar 16 2006, 12:07 AM
Me? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Nope...I'm all set. Good balance, very predictable. KT |
Andyrew |
Mar 16 2006, 02:30 AM
No not you trekkor... I know your setup is dialed... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
His pic shows the front tire almost in the air.. To me, that means more spring (unless thats how he likes to drive..) |
J P Stein |
Mar 16 2006, 09:04 AM
This combo get's lost in the shuffle of bigger is better
or more cool, yada. Stock front T bars. 19mm adjustable front AR bar 140/150 lb rear springs. No rear AR bar. I used to run the AR bar full soft. The car was neutral....maybe just a tad loose. I ran it wiith larger rear than front tires (205 & 225s), so it may be a bit tail happy with equal sized tires. If so, tighten the front AR bar. |
Joseph Mills |
Mar 16 2006, 09:17 AM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) yada yada (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) .. |
J P Stein |
Mar 16 2006, 10:09 AM
Got an old pic of my car with this setup.
Some folks get all goosey about lifting the front wheel.....I ain't one of them (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Attached image(s) |
Trekkor |
Mar 16 2006, 10:18 AM
J P Stein |
Mar 16 2006, 10:28 AM
I've not seen any pics of my car lifting the fronts lately....but if it doesn't, there can't be much weight on that inside wheel no how. The camera has to catch it at the right time.....OTG at or around an apex. This is about as close as I have.
Attached thumbnail(s) |
Jeroen |
Mar 16 2006, 10:41 AM
his inner front aint lifting... he just has lots of roll because he has no swaybars |
J P Stein |
Mar 16 2006, 10:56 AM
hummm...
mikeyb33 |
Mar 16 2006, 01:55 PM
"needs more cowbell" (heh - just had to say it...) maybe a bit of oversteer due to throttle and/or high steering input at lower speeds, but overall pretty neutral. Next question: Given all the different comments/opinions on what the "best" setup is, has anyone posted a basic 'primer' on what each of the different mods. to a car's setup will do to its handling? I"ll admit I'm pretty ignorant on car setup - I usually just climb in & (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Jeroen |
Mar 16 2006, 04:58 PM
basically, the end that you stiffen up looses grip first
so... more front swaybar or springs (torsion bars) makes more understeer or less oversteer more rear swaybar or springs makes more oversteer or less understeer so if you upgrade the front, you'll need to take appropriate measures in the rear as well JP's suggestion (19mm adj.front sway and 140 or 150# rearsprings) sounds like a good starting point from there on it's a slippery slope (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
grantsfo |
Mar 16 2006, 07:34 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I know I will have to do some suspension tuning to my six conversion as well. Currently it has the following:
Front Tbar 19 mm Front sway 22 mm Rear springs 200 lbs Tires 265 and 225 I think ultimately I will go with a bigger front SmartRacing Bar and 225 or 250# springs in the rear. I will have to suffer until I recover from my conversion costs. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:36 AM |
