FI Boots, Injectors, MPS, throttle switch |
StratPlayer |
Mar 17 2006, 12:09 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Is there a certain method to installing new boots? Hoping nothing has to be cut to install these...
StratPlayer |
Mar 18 2006, 12:17 PM
JeffBowlsby |
Mar 18 2006, 12:48 PM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
No cutting needed. You need to remove the wire terminals with a small probe. Be sure you know which wires go into each cavity, the order is important on the MPS, dizzy and TPS.
StratPlayer |
Mar 18 2006, 01:32 PM
Thanks Jeff (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 9th May 2024 - 11:12 AM |
