springs?!, WTF |
springs?!, WTF |
ChrisFoley |
Mar 19 2006, 12:13 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The rate of a coil spring is dependent on wire length and diameter in addition to metal composition, nothing else. When the close coils of a "progressive" spring go into coil bind the wire is effectively shortened causing a higher apparent rate. Therefore calling them "progressive" is a misnomer. They have only two distinct spring rates and there is nothing progressive about them. What Andy experienced and what Erik described have nothing to do with the compression rate of the spring coils, only inertia. The coils at the suspension arm end of the spring are being accelerated when the arm moves. Putting the closely spaced coils at the bottom means they will slow the movement of the suspension more than the other way around due to the greater mass of coils. On a lightweight motorcycle driven over bumps and jumps this will give a similar feeling as a higher rate spring. Andy's experience with motorcycles has no application here - it's apples and oranges. Whatever he experienced at autocrossing had nothing to do with inverting the springs in spite of his belief that it was the only thing that changed. (just my opinion!) The same feeling won't be experienced on a car since other factors play a much bigger role. If you want to reduce the unsprung weight you will have to live with a higher center of gravity and vice versa. Put them either way and you won't notice any difference unless you are a very talented driver and your car is a well built race car. But race cars typically don't use progressive springs because drivers don't want to experience a sudden change in spring rate when entering a corner. The comfort value of progressive springs is only for bumps on public roads. BTW, I got a good laugh while reading the old discussion. Talk about people taking themselves too seriously. It's just like creationism vs. evolution. Both sides think in order for them to be right the other side has to be wrong. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif) |
sk8kat1 |
Mar 19 2006, 07:41 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
so it seems by looking at the yellow spring in my .. would I be correct in saying that the PO had cut off the "progressive" section off the spring........
ChrisFoley |
Mar 19 2006, 07:52 AM
Only if they started life as progressive springs. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) If you had rear shocks with adjustable perches like Bilsteins you could install them and find out how they feel without suffering from the car being to low. |
GaroldShaffer |
Mar 19 2006, 08:10 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
My car last year at a AX in South Bend with those yellow springs installed. The front of the car was a low as I could get it without reindexing the front. Konis set at full firm up front and 3/4 rear. Other than having the konis set to full soft during street driving this is the way I always drove it. To low you tell me? sat like ~ 5.25 inches off the ground measured at the donuts. YMMV (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
EDIT - all this with non adjustable pearches Attached image(s) |
ChrisFoley |
Mar 19 2006, 08:36 AM
Garold,
That looks pretty darned good actually. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
sk8kat1 |
Mar 19 2006, 10:17 AM
huh then I wonder what these welts are to do to the back end of my car...
what tires are you running in that pic? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
GaroldShaffer |
Mar 19 2006, 11:30 AM
falken azenis 205/50/15
Mueller |
Mar 19 2006, 01:01 PM
just install the darn springs and find out...it should take you less that 30 minutes to remove and replace the springs.....it's not a hard or difficult job...are you sure you have bone stock spring on the car and that the PO has not changed them?? |
McMark |
Mar 19 2006, 03:34 PM
How about a couple close up pictures of the ends of the yellow spring. Should be pretty easy to see if they've been cut or not.
Lo-Fi Version | Time is now: 5th May 2024 - 04:07 AM |
