OT: I'm buying a lift, 2 post or 4, that is the question |
drew365 |
Sep 10 2003, 08:08 PM
I've priced lifts and made arrangements to have a used 2 post 9K# lift installed next week. Now I'm having second thoughts. The dealer also has a used 4 post. They're about the same price. I decided the 2 post would be much better for repair work. I'm concerned that the car that will be stored on the lift will have problems from the suspension hanging all the time. I don't want to have to hassle taking the wheels off of it each time I lift it, and don't know if that would alleviate the problem anyway. What would you guys do? Is there enough room between the ramps of a 4 post to do a engine drop? (IMG:style_emoticons/default/idea.gif)
boxstr |
Sep 10 2003, 08:18 PM
Jim Chambers has a four post lift and he and I have installed a motor and R&R a trans. It is a bit skinny between the ramps so you have to adjust. Also the ramps limit some of the jacks and other devices that you are able to get under them.
I have used a two post lift and it has its good and bad points. But I think if you are going to be R&Ring running gear allot I would go with the two post lift. The four post lift you have to jack the car up if you want to do brake or suspension related work. That means a small jack on the ramp, while the car is at the optimum height. The four post jack you can move a car around while on it, the two post is staitionery. Good luck. CCLINYOUDONTKNOWJACK |
cha914 |
Sep 10 2003, 08:54 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
I think if you are going to use it mainly for work on the car then stick with the two post. But if storage is your main thing then go with the 4post. I donno...personally the only reason I would want a 4 post is if it was an alignment rack...
Is the two post you are getting a symetrical or a-sym? open top or closed? I have a symetrical open top two post and I like it alot, but it is a little harder to get the bigger vehicals on it. My buddy has an a-symetrical closed top, which is actually easier than mine to use, but it is a closed top, so you have to have at least a 15ft celing to use it. Either way, you are getting off the ground, which is what it is all about... good luck, Tony |
drew365 |
Sep 10 2003, 09:11 PM
They are supposed to install a symetrical open top 2 post. My only concern is what kind of wear will I get from the top cars suspension hanging. Parts for the upper car are not available at FLAPS. I want to keep the 914 on the ground since it will be used more.
Joe Bob |
Sep 10 2003, 09:17 PM
GROUP BUY!!!!!!!!!!!!!!!!!!
I want one too, as does my neighbor..... brad@aclifts.com I have been talking to this guy....email me at 356@cox.net and I will send brochures that were emailed to me...... |
-P- |
Sep 10 2003, 09:41 PM
P-Factor Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 |
I've been thinking of one of the smaller scissor type ones from Bendpak.
Model MD-6XP Description Model MD-6XP Portable Mid-Rise Scissors Lift Perfect For Servicing Light-Duty Trucks And Cars. Portable Motor Cart Serves As Tow Handle To Easily Move Lift From One Bay To Another Adjustable Arm Assemblies Safety Lock Bar With Multiple Lock Positions Fast And Efficient Operation Lifting Capacity: 6000 Lbs. Overall Width: 40” Overall Length: 81” Lifting Height: 48” Minimum Pad Height: 4-3/4” Attached image(s) |
drew365 |
Sep 10 2003, 09:48 PM
P; the sizzor lift looks good for repair work, but I have one too many cars so my lift has to double as a repair lift and storage lift for the extra car. There was a pretty long thread on the sizzor lifts on the Pelican 911 board. Do a search and you'll get some good info.
-P- |
Sep 10 2003, 09:51 PM
Yeah I hear ya. If my garage was high enough I would go with a 2 post over a 4 post jsut because it is easier to work on the car, but I see your concern about the suspension. I'm sure you could rig something up to take the load off.
seanery |
Sep 10 2003, 10:08 PM
2 post lifts are as strong as a four. We used to always pack a car under a car on the lift at my mechanics shop, every night.
I like the convenience of the the two post lift. If I had enough height, I'd have one right now! |
fiid |
Sep 10 2003, 10:16 PM
Can I ask how much this is going to cost you? I want one so I can have another car. Or at least be able to get one more in the garage and not have to fight with the evil neighbors accross the street that have like 4 Crown Victorias (WHY ON EARTH??)
l8r, Fiid. |
drew365 |
Sep 11 2003, 08:19 AM
fiid; lifts from Eagle which is one of the main residential dealers cost about $2,700. Others with more bells and whistles are $3k to $4k. I'm getting a commercial, year old one that was repo'd for $1,600 plus $300 install.
GaroldShaffer |
Sep 11 2003, 09:14 AM
How much height do you need for a lift??? You guys
got me thinking (IMG:style_emoticons/default/blink.gif) |
fuch toy |
Sep 11 2003, 09:25 AM
Unregistered |
QUOTE(drew365 @ Sep 11 2003, 06:19 AM) fiid; lifts from Eagle which is one of the main residential dealers cost about $2,700. Others with more bells and whistles are $3k to $4k. I'm getting a commercial, year old one that was repo'd for $1,600 plus $300 install. Has he got anymore repos????? |
seanery |
Sep 11 2003, 09:28 AM
mskala |
Sep 11 2003, 10:24 AM
Ginter got me started when he got a 4-post. I got the same thing. It is great if it fits
what you want to do. I agree with the others that 2-post is better if your main goal is working on the car, and on a 914 almost everything you work on is connected to the wheels (IMG:style_emoticons/default/smile.gif) . For having an extra car and getting it up and down maybe a few times a week, 4-post is better. I can dig out some of the stats for mine if you want, but the 914 is short enough that you can store a car under it with a 9.5' ceiling. Depending on your setup some maneuvering can get you more. I can take the roof off, straddle a rafter, and get the 914 so I can walk under the car without ducking (5'10" me, 9'5" ceiling). For the 6-cyl engine, with a Gemini 7000lb standard model, the rails will allow the engine to come out, but the tin must be removed first. |
LvSteveH |
Sep 11 2003, 11:01 AM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Great topic. I just picked up a lift that has the advantages of a 4 post, and the accessibility of a two post. It’s a design I’ve never seen before, and is basically a single post. It has a 7000lb capacity and has full ramps that can be removed to use standard swing out arms that pickup at chassis lift points. It’s hard to explain, but it seems to be great for the 914. Now if I can just get my freaking garage built. Oh, and it doesn’t need to be bolted down. Here’s a pic, maybe that will help clarify.
Attached thumbnail(s) |
seanery |
Sep 11 2003, 11:18 AM
Discount Tire uses those. They don't go very high do they?
LvSteveH |
Sep 11 2003, 11:30 AM
The unit itself is almost ten feet tall, and the ramps go up to around six feet, maybe a bit more, it was well over my head. The only down side I've seen is that it's a little tight to do transmission work on trucks, as there are two arms that are around 30" apart that go under the center of the vehicle. If you used the ramps as opposed to the arms, then there would probably be plenty of clearance for transmission work on trucks and typical rear wheel drive cars. Just about every lift I have seen was a compromise in one way or another.
aufaber |
Sep 11 2003, 11:34 AM
Member Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 |
QUOTE(seanery @ Sep 11 2003, 09:18 AM) Discount Tire uses those. They don't go very high do they? The Hydrolic ones go high enough to stand under. -Aaron G. |
seanery |
Sep 11 2003, 11:52 AM
cool, are they safe?
Lo-Fi Version | Time is now: 19th May 2024 - 02:43 PM |
