Wheel options, wider wheels on a gt flare conversion |
hollandhill |
Mar 19 2006, 01:14 PM
Newbie Group: Members Posts: 20 Joined: 26-September 05 From: Ct. Member No.: 4,867 |
I am having my '72 3.0 sc conversion car flared with GPR steel fenders. Question is what options do I have when choosing new wheels. I currently have 7 inch fuchs that I will likely be selling. Weight will be high on my list when choosing new wheels , the car is a DE /weekend car. Here's a link to the car before flares. http://forums.pelicanparts.com/showthread....threadid=238716
Mueller |
Mar 19 2006, 02:26 PM
a lot of GT flared cars run 16x7 Fuchs up front with a 1" spacer and 16x8 Fuchs in the rear (225 and 245)
what is your realistic budget? are you willing to go up to 17" or 18" rims? just one set of rims and tires for everything or can you deal with street tires and track only tires?? |
Mar 19 2006, 02:39 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
factory GT combos:
- 7" front with 1" spacer, 8" rear with 1" spacer - 8" front, 9" rear (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
d914 |
Mar 19 2006, 03:03 PM
9's in the rear you need a et of 15...some bbs and some fuchs etc
VegasRacer |
Mar 19 2006, 03:13 PM
ELVIRA Group: Benefactors Posts: 8,501 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
What size rims? 15", 16", 17", 18"?
15 & 16 will weigh less. 17 & 18 will give you more tire choices. I run 16 x 8's for the street and 16 x 8's & 9's for the track. |
hollandhill |
Mar 19 2006, 04:45 PM
I'm thinking 16 inch re: can clear 930 brakes if I ever upgraded. I also like the look if a smaller wheel on a 33 year old car. What are the non fuch options to end up with 16x8 and nines. For now I'd like to use of set of rims for everything. Budget?? $1500 btw will my 15x7's work up frnt and look for 15x8's for the rear. If so where should I look for the 8's.
Mueller |
Mar 19 2006, 05:53 PM
I'm 90% positive that true 930 brakes fit under a 15" wheel..... it's harder to find 16" tires to fit 9" rims....255's are made, but they are normally in the 50 series and might be on the tall side, not sure what diameter you want to run, so look into tire selections 1st. yes, you could use your 15x7 up front, I'd run a 1" spacer so the wheels don't look "lost" in the wheel well... |
Mar 19 2006, 05:58 PM
245/45 will fit on a 9" wheel ... but i agree, wider tires for 15 or 16 wheels are hard to find these days ... btw. i'm still looking for a set of 285/40 x 16 street tires. *ANY* brand will do! HELP! (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
STL914 |
Mar 19 2006, 10:17 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
If someone had 15 x 6" Fuchs, would it then stand to reason that 2" spacers could be used to fill the flares?
Mar 19 2006, 10:37 PM
probably. that would also mean 100mm wheel studs ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
Lo-Fi Version | Time is now: 5th May 2024 - 08:59 AM |
