Engine over revved, Now it won't start? |
vesnyder |
Mar 20 2006, 02:03 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
It appears my throttle cable stuck and my car revved to the max on my tach - only for a moment before I shut the car down. It did this twice, but I was able to carefully drive the car home and it seemed to run OK. Even started back up several times on my way home, but will not start now? Did I do permanent damage? Any way to tell - drain oil and see what metal comes out? Any chance it is something simple like need to change the plugs? HELP?
Joe Bob |
Mar 20 2006, 02:09 PM
Describe won't start.....
Turns over and won't catch..... Turns over catches and sputters.... Won't turn over and just clicks.... Won't turn over and sounds like it's seized? |
Mueller |
the motor just wants to take a "nap" give it another day and it'll be fine (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
seriously, does it at least turn over with the starter?? FI?? and if so, which one?? |
Brando |
Mar 20 2006, 02:11 PM
Drain that oil, magnet in hand.
Possible you floated the valves and had some interference. Check the basics... Fuel, spark, no air leaks. Injected or carbureted? |
vesnyder |
Mar 20 2006, 02:14 PM
It turns over like it is going to start, but never does? Almost sounds like it is not getting any gas and/or spark - hope this helps? It has the stock L-jet on a '73 1.7.
914-8 |
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
yep, check the basics - fuel, spark and compression.
did you have any kind of rev limiter in place? if you suspect that the overrev has damaged the engine, try the compression check. if your compression is fine, you are a good way towards being out of those woods! |
914-8 |
Mar 20 2006, 02:17 PM
we posted at the same time.
if you don't have a compression tester handy, try quick checks to see if you are getting fuel and spark. pull a plug, ground it to the engine and see if you are getting spark. then pull an injector, stick it in a bottle and crank to see if you are getting fuel. you'll know a lot more after that 15 minutes of tests. |
914-8 |
Mar 20 2006, 02:19 PM
one other easy test - try using some starter fluid to start it. shoot some into the intake per the instructions on the can, while someone is trying to start the car.
If it starts and runs for even a very short while (couple seconds), you know for sure you have a fuel problem. |
Joe Bob |
Mar 20 2006, 02:22 PM
After checking for spark....and you have spark....
Give it a shot of ether/quick start while cranking the starter.....if it starts you have a fuel problem....fuel pressure too low.... If no start, probably low compression due to valve train issues. Check compression and see if the valves are adjusted out of spec. |
vesnyder |
Mar 20 2006, 04:54 PM
OK - I figured out it is fuel related? When I give it a shot of starter fluid it rund for 10 sec or so then dies? I also checked the fuel pump and it is working - what else could it be?
Mar 20 2006, 05:40 PM
Resident German Group: Admin Posts: 41,643 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
out of gas ??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
tod914 |
Mar 20 2006, 05:48 PM
I had a simular problem... bad cpu, but I understand that's unusual that they go bad. Regarding your throttle cable, if they are installed wrong, they can wrap around the clutch cable and get stuck like that.
914-8 |
Mar 20 2006, 05:54 PM
Been a while since I've had D-Jet, but from my recollection, the next thing I'd do is pull out the electrical connections from the injectors, use a standard 12v test light, and see if they are getting any power when the car is cranked.
vesnyder |
Mar 20 2006, 08:03 PM
As embarassed as I am, the car was out of gas - sorry? The fact that I drove it into the garage I could not beleive that was it? I just installed a new gas gauge and it needs calibrated. Thanks for your help!
Mar 20 2006, 08:08 PM
what do i win? (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) Andy |
shaggy |
Mar 20 2006, 08:11 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
hahahahahahaha! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
a little embarassment to save $1000 on a rebuild? id take that any day! at least your gas gause works, or is about to mine on the other hand, i have to take a corner hard and watch for an orange light (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) -shag |
Joe Bob |
Mar 20 2006, 08:20 PM
Doh!.....people on 'ludes shouldn't drive.....
Jeff Spicoli Fast Times at Ridgemont High |
vesnyder |
Mar 20 2006, 08:47 PM
Embarassed but relieved! My stupidity amazes me sometimes - too many ludes in my prime?
Allan |
Mar 20 2006, 08:51 PM
So car is running well?
No funny noises? |
porschecb |
Mar 20 2006, 08:52 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
Do not forget the stuck cable! (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 02:24 PM |
