Oil Light not Working, What should I check? |
vesnyder |
Mar 20 2006, 08:14 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I just connected an oil pressure gauge and sender and the light worked fine for a couple days and now it does not go on at all? What voltage should I be seeing at the two leads?
Cap'n Krusty |
Mar 20 2006, 08:16 PM
Turn the key on and ground the wire for the light, right at the sender. ZIf the light comes on, then you have a sender problem. If not, you have a problem after the sender. Then you check the bulb, followed by the wire. The Cap'n
Lo-Fi Version | Time is now: 8th May 2024 - 09:15 PM |
