TomMarcellino |
Newbie ![]() Group: Members Posts: 4 Joined: 6-March 06 From: Dayton, OH Member No.: 5,677 ![]() |
Hey all, I posted here a way's back and some of your members helped here and over on the X1-9 forum very nicely. Just wanted to post my final results of converting my X1-9 to a GM alternator with internal voltage regulator. Thanks for all of the help!!
Took me a little while searching bits and pieces to do my alternator conversion, so I thought I'd lump it together if anybody else is considering. Nice change and not difficult or expensive. 1300 motor, mounted a GM alt with internal voltage regulator. Used an alternator for a "78 Camaro w/350" and wiring adapter, straight off the shelf at Advance Auto, $50.... crimp an "eye" on the red/battery wire and connect to output of alternator along with the brown wire to the starter. 1/4" spade on the white wire goes to the blue/violet wire you disconnect from back of orginal alt. http://www.socalx.com/x19/gallery/displayi...m=77&pos=21> Take the bottom bracket from the block and cut it back an inch. before and after pic's side by side, note the pencil line on the left: http://www.socalx.com/x19/gallery/displayi...m=77&pos=22> Adjustment arm and spacer tube from Pep Boys, $15 (?). Remove the original top alternator mount completely, not needed and interferes. Cut this arm down to fit to the nearest water pump bolt and drill a hole in it. You will need to cut about an inch of the spacer tubing to go between the bracket and the alternator. http://www.socalx.com/x19/gallery/displayi...m=77&pos=23> I used the original belt and the "walk on" method because it was tight. The splash guards both mounted back up normal, so I know I have it in the right place. Turned out to be half the cost of special ordering a replacement Marelli or Bosch and now if it dies, more easily and cheaply replaced. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) Grazie! Tom 74 X1-9, 1300 Dayton, OH |
Lo-Fi Version | Time is now: 13th July 2025 - 10:33 AM |
