OT: 901 trans compatibility question |
EMRoadster |
Mar 22 2006, 10:46 PM
Autocrosser Group: Members Posts: 65 Joined: 20-August 05 From: Tucson, AZ Member No.: 4,620 |
I have someone looking to buy my two 901 trannys for his project vehicle. He has two different engines he's trying to decide between to use. Both are `67 blocks, one from a Bug and one from a Bus. The question is whether a 901 trans will work with either of these blocks?
Thanks, |
dimitri |
Mar 23 2006, 05:12 PM
dimitri Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 |
Either one will bolt right on to the transmission. Dimitri
Rand |
Mar 23 2006, 05:30 PM
What kind of project vehicle? Just make sure it faces/turns the right direction so you don't have 5 speeds in reverse.
Bleyseng |
Mar 23 2006, 05:47 PM
Depends if it a 901 or a 914/12 coded tranny. A 901 with the shifter lever out the back is from a 911/912 which needs a rear engined setup.
A 914/11 or 914/12 is for a mid-engine set up cuz they flipped the diff so you have 5 speeds forwards. The 901 with the rear shifter works best in a bug conversion set up |
EMRoadster |
Mar 23 2006, 07:37 PM
Don't know for sure what his project vehicle is but it is rear engine. So he would be taking the parts from the 914 sideshift trans to complete the 911/01 trans and install it in his car. He just didn't know if the 901's and Bug and Bus blocks would be compatible.
Thanks for the info! This will mean a few more dollars for my autocross Roadster project! (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) |
Lo-Fi Version | Time is now: 28th April 2024 - 02:09 PM |
