912 Trans compatibility, can I use the guts |
pek771 |
Mar 26 2006, 07:36 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
If one were to take an old 912 trans with attractive gearing, pull out the shafts, will these fit into a 914 box? I am still unsure of compatability of these two trans.
Thanks! Pat |
ClayPerrine |
Mar 26 2006, 07:38 PM
The 912, other than the 912E, uses a 901 gearbox. The parts inside are interchangable with a 914 gearbox.
pek771 |
Mar 26 2006, 07:54 PM
Thanks, Clay.
Is there any way of telling by case numbers, etc, the difference between a 912 and a 912E trans? Pat |
ClayPerrine |
Mar 26 2006, 07:59 PM
A 912E trans was only used in 1976, and it looks just like a 915 trans out of a 911. The only difference is the clutch throwout arm and the input shaft. But they are fairly rare. |
Bleyseng |
Mar 26 2006, 08:04 PM
I am running 3rd and 4th outta a 5 speed 912 gear box. Nice close ratios for upshifts and downshifts between 2nd thru 4th in my 2056 power band. I kept the stock ZD 5th for freeway drives.
Exchange the gear sets not the shafts (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
pek771 |
Mar 26 2006, 08:14 PM
Thanks again:
This is for the 2.7 track car. Seems I'm having a bit of trouble finding an already built side shift trans, so I figure I'll collect some gearsets in case I have to build one. Supposedly this box has a real high ring and pinon set also. Pat |
Bleyseng |
Mar 26 2006, 08:31 PM
Get the one in the best condition as parts are getting expensive. Sliders, dogteeth in good condition are a must in buying a "good" box or its just a core tranny.
Pull the gear cluster out if you are going to buy a box and look closely at it. If you need some tranny reading, read Redbeard's articles. |
Lo-Fi Version | Time is now: 15th May 2024 - 09:03 PM |
