M caliper, Banjo fittings |
DanT |
Mar 27 2006, 11:37 PM
Thanks for the words Eric. If I find a set of rear Ms I will give the removal of the spacers a try. Now that I have some measurements I think it might work.
And if it works I will send you the "extra pieces" |
Eric_Shea |
Mar 27 2006, 11:51 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
You'll get the side mouting brake line you want and I do believe the measurement will be correct.
To get an M to work with a vented rotor on a teener you need a 5mm spacer behind the rotor. Exactly the same spacer you need to get a V-Caliper to work. Take away your 10mm caliper 1/2 spacers and that 5mm rotor spacer and you've got yourself a caliper that will bolt on a stock teener rotor. |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:59 AM |
